Old 02-03-2009, 08:23 PM
dakos dakos is offline
Switching temp display from Farenheit to Celsisus?\
I was just wandering if that may be possible..not that i already got almost used with the F degrees display
thanks
Old 02-03-2009, 08:26 PM
Re: Switching temp display from Farenheit to Celsisus?\
It's actually reasonably simple. There's a connector under the dash that needs to be plugged in, or unplugged...I can't remember the exact details, but that's the idea. I will search.
Edit: Found!
Remove the kick panel on the left side of the car. You may have to slide it up a bit to get it out of the door trim.
Locate a white electrical connector with a SINGLE black wire going into both sides.
Pull apart the white connector.
That's it. Put the panel back on, start the car, and turn on your aircon. The temperature is now in celcius!
Old 02-03-2009, 09:26 PM
IceBlade's Avatar
IceBlade IceBlade is offline
Send a message via MSN to IceBlade
Sweet. I had no idea this was possible. Thanks
Old 02-03-2009, 10:36 PM
In the How-To Docs.
Old 02-04-2009, 03:49 PM
Thanks a MILION!!
this was the quickest fix ever...less then 30 sec )))))).. i've pulled out the panel and the wire "jumped in to my hand"..right in front of my nose ) disconnected and "voila" ! ...-13 C outside )))))))
Thanks again!
