Old 05-27-2008, 01:21 AM
JLHollowX13's Avatar
JLHollowX13 JLHollowX13 is offline
Send a message via AIM to JLHollowX13
which parts?
on these pages, which parts do i need to replace the speedo gears in the differential? they are not very expensive, so i could just buy them all and replace them all, but if i do that, are there any other parts i need to get too?
http://www.subaruparts.com/diag/?mod...category=156-A
on this one, its part # 11 and 19
http://www.subaruparts.com/diag/?mod...category=190-A
on this one, its part # 17
im just giving the obvious speedo parts. do i need all these and is there anything else i need? i want to have all the parts before i drop the tranny out and start fixing it all.
thanks for any help!!
1992 silver/black LSL - 142,xxx miles
power mode switch, ecu crush, intake silencer removal, ecutune, B&M transmission cooler
1971 toyota landcruiser - project.... someday
Old 05-27-2008, 02:12 PM
kwren's Avatar
kwren kwren is offline
This probably didn't work the way you intended...
Old 05-27-2008, 02:55 PM
Maxo's Avatar
Maxo Maxo is offline
You have to be logged into that site to see those images.
If I had to guess I would say that you only need #11. That's the part that contacts with #17 and is what probably what is broke.
I recently swapped out a broken front diff and none of the speedo parts were damaged. While examining the diff I thought that #17 looked pretty robust but I suppose since it is just plastic it could be damaged too.
