Old 04-22-2008, 09:38 PM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
starting problems
in short, occasionally when i try to start the car, the engine doesn't turn over at all
ill let the car sit for a couple minutes and then it'll start up right away
and...idk if this has any connection with the problem above, but in the mornings when i start the car, the engine will turn and catch the first time, but then immediately die
i start it a second time and its fine
could this be because of a low battery?
i really dont know
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 04-22-2008, 11:52 PM
kwren's Avatar
kwren kwren is offline
probably not
Old 04-23-2008, 09:50 AM
STORMINORMAN STORMINORMAN is offline
Lightbulb You can always...
...1) check the battery. An old wornout battery can do this a lot.
2) I've had a switch/ignition cyliner issue (for about 4 years) where if you wiggle the key a bit it starts every time. The shop suggested I needed a "new or rebuilt starter" at that time... Needless to say the car has been starting for the last 4 years so I didn't follow their advi$e.
Cheers!
' 92 SVX @ 185K
' 91 420SEL @ 223K!
' 88 420SEL I. @ 178K (what a buy!)
' 87 F250 @ 180K
' 93 ZX-11D @ 29K
' 93 SC400 @ 93K
2001 Valkyrie Interstate @ 6.6K (Brynhild)
Y2K NightHawk 250 @ 1,500 miles
' 88 420SEL II. @ 208K
'85 F150 @ 135K
Old 04-23-2008, 11:58 AM
dcarrb dcarrb is offline
A new ignition switch seems to have cured the intermittent, turn-the-key-and-hear-nothing problem for me.
dcb
