Old 04-22-2008, 05:44 AM
Dessertrunner's Avatar
Who has had to replace the heater coil.
It seems that the old girl is showing its age (or maybe the hard life we have shared). Last night I noticed the water temp running high again and today I tracked down the problem to a hole in the heater coil. Didn't have to be smart to figure out that the water with coolent under the carpet was from there. So has anyone got any suggestions on how to tackle the job it would be greatly appricated.
Tony
Old 04-22-2008, 02:26 PM
immortal_suby's Avatar
Thread Killah
I've done it. It isn't fun. You have to remove the center console, drop the steering column, remove the dashboard, loosen enough to pull back out of the way or remove the steering support bar completely*, and then it's still pretty tough to get the heater box moved far enough back to get to the screws that hold the heater core in.
*The FSM says to remove the steering support bar. I just loosened both sides and then pulled it back far enough for clearance.
In the meantime - bypass it before your carpet is destroyed!
I can post the pages from the FSM if you want.
Locker Link
2015 BRZ Limited 6MT
Old 04-22-2008, 09:12 PM
AGREENTREEFROG's Avatar
AGREENTREEFROG AGREENTREEFROG is offline
TREEFROG
Cores
Hey Tony If Youre Going To Get Aluminium One Made (i Just Thought You Might) Can You Come Visit Me Cheers
Andy
Old 04-23-2008, 04:14 AM
Andy I thought it would go one day so I had one shipped from the USA about 2 years back. Will try to bring in the new car as soon as I can.
Tony
Old 04-23-2008, 04:20 AM
Forgot to ask when you remove the water heater can you get to the front top vents. Mine have cracked lose from the dirt roads and I was going to pull the dash for that job so now as the saying goes I get to kill two birds with one stone. I have the manual thanks.
Tony
Old 04-23-2008, 03:43 PM
Thread Killah
yes, you'll have a great view of the vents with the dashboard out.
Locker Link
Old 04-23-2008, 05:52 PM
TREEFROG
Core
Tony
OKAY CHEERS
Old 04-24-2008, 02:29 AM
Thanks Matt I plan to tackle the problem on the weekend so wish me luck. How long in time did it take you?
Tony
Old 04-24-2008, 07:15 PM
Thread Killah
The actual job took me about 4 hrs, beer included.
Then realizing I had no speedo when I finished I spent another day pulling the dash again and troubleshooting to find out what I had done wrong....
http://www.subaru-svx.net/forum/show...ht=heater+core
Locker Link
Old 04-30-2008, 04:57 AM
Matt did you by any chance blow a head gasket or change your radiator cap to an STI one. Reason I ask is that the heater coil didn't get a hole in it what happen was the top tank split from to high a pressure.
Tony
Old 04-30-2008, 03:08 PM
Thread Killah
Interesting.
I blew a head gasket on a previous engine. I blew a top tank on a previous radiator.
35,000 miles later on a different engine, a PWR radiator, but a stock subaru radiator cap was when my heater core failed. It did not burst like yours did though, it was a pinhole leak. My heat still worked, it just smelled like antifreeze and fogged up the windshield when I turned it on.
Locker Link
Old 04-30-2008, 03:11 PM
Thread Killah
I forgot to ask - how long did it take you to get that heater core out?
Locker Link
Old 04-30-2008, 04:48 PM
I think all up about 10 hours but that is due to the fact that I had to do a number of changes and repairs while under the dash. I have to put in the speedo corrector after the ECU and before the speedo other wise it screws the cruise control. Also installed new wires from engine bay to runing the fans on manual, read two tempreture guages, driving lights and a few spares wires for later.
I think the build up in pressure when we do the head gaskets causes the problem. Only SVX I have heard of doing the heater have all done there head gasket as well.
Also I am aiming to get some photos to show which bolts etc to undo.
Tony
