Old 04-03-2008, 12:55 PM
kwren's Avatar
kwren kwren is offline
Why???????
I noticed in the how 2's this Throttle Body Bypass Mod.
Take the coolant hoses off both sides of the Throttle Body and fasten them together???????????/
Again, why?????
anyone have a clue?
Thanks,
Keith
Old 04-03-2008, 01:11 PM
dragoontwo dragoontwo is offline
I would imagine it's so the coolant still flows in the same path, but bypasses the throttle body.
'92 SVX LS Pearl White - 6mt
Old 04-03-2008, 01:15 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Winner.
I don't know how much of a difference it makes, though. Mine's as-was.
Old 04-03-2008, 02:48 PM
crazyhorse's Avatar
242,000 mi on oem trans
The theory is, that the coolant heats the TB's. This actually does help a couple things. First, it prevents icing in the coldest extremes, second it helps suspend the fuel in the airstream just slightly better. Not for better performance, but better emisions.
There is so much debate over wether this actually makes a difference. Not just here either. My 2bits is, if you're having slight detonation problems, bypassing it is a cheaper alternative to increasing octane. Also, if you've bumped the compresion, or are running mild boost, this will help cool the air charge. I did the bypass on a 5.0 mustang & if it gave me any results, it was the ability to add a degree or two of timing before detonation occurred.
BTW when setting a disty I start with the factory setting, then bump it up until detonation occurs, then step back one notch.
"42"
Current Stable By Age:
