Old 08-03-2007, 06:01 PM
wannarace928's Avatar
wannarace928 wannarace928 is offline
Send a message via AIM to wannarace928 Send a message via Yahoo to wannarace928
Classic SVX
A/C finally works, but now...
I just had the teal's A/C completely fixed, it WORKS, it works, it works!!!!!!!!! (very happy!)
However, 2 times since I have gotten it fixed, I have tried to accellerate and got nothing, no RPM raise or anything, even with the pedal to the floor... this is after the car has already started moving and may be around 20-35mph Happens for a couple seconds, then it runs fine. Any idea's?
1992 Subaru SVX 5spd
1998 Pontiac Firebird Formula
1999 Chevrolet Camaro SS
2009 Subaru Forester - Mileage Junky
2009 Pontiac G8 GT
2017 Ford Mustang GT 6spd
Old 08-04-2007, 11:42 AM
Kelvin Kelvin is offline
Banned
Sounds like a bad TPS sensor. That'd be my guess.
Old 08-04-2007, 06:54 PM
redsvx's Avatar
redsvx redsvx is offline
Alcyone ... the brightest star
Kelvin
I'd second that ...
A faulty TPS can cause driveability problems such as ...
hesitation, stalling, an erratic idle, pinging, no torque converter lockup, hard starting, an intermittent check engine light while driving, poor fuel economy, and generally poor engine performance.
92 SVX LS Pearl
94 SVX LSi Barcelona Red
82 Brat 4WD
Bob
Old 08-04-2007, 07:51 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
When you accelerate hard with the AC on, I think the AC clutch should disengage until the ECU believes you're back to cruising mode. Does the hesitation occur when you don't have the AC on?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-04-2007, 10:00 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
I'll take a look at it when I have the car in a few weeks. I hope to have a select monitor up and running by then with any luck.
Old 08-04-2007, 11:02 PM
94SubieSVX's Avatar
OOC for a while
What exactly is a TPS sensor and what is it's function? Just curious as I'm relativly new to thorough engine work.
bLAh
Old 08-05-2007, 08:02 AM
redsvx's Avatar
94subieSVX
The TPS is used to supply the ECU (Engine Control Unit or computer) with critical information such as idle status and driver demand. Think of the TPS as a sophisticated accelerator pump in a carburetor. The TPS informs the ECU when the engine is at idle, when the driver opens the throttle, how much the throttle is opened, and how quickly. The computer uses that information to make adjustments to fuel delivery and spark advance.
redsvx
92 SVX LS Pearl
82 Brat 4WD
Bob
Old 08-05-2007, 08:13 AM
94SubieSVX's Avatar
OOC for a while
Very well said Thanks, now my brain is bigger
bLAh
