Old 08-18-2007, 11:56 PM
94SubieSVX's Avatar
OOC for a while
I'm probably going to try a different inspectin station next time. But for now I'm gonna get the exhaust checked out just to be safe and then re-inspect it for the 4th time
....Oh wait I already broke
bLAh
Old 08-19-2007, 12:01 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Replace the primary cat...
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-19-2007, 12:05 AM
94SubieSVX's Avatar
OOC for a while
-Bill
Do you think that that could have caused the reading to go up 500%? It's only been a few weeks since the 2nd inspection.
bLAh
Old 08-20-2007, 10:31 AM
redsvx's Avatar
redsvx redsvx is offline
Alcyone ... the brightest star
I don't ... there has to be something out of whack. I think it's time to try an independent shop or two. I've never seen a reading that high. Even some catless systems can be lower.
Ever heard of a catch-can system put in the pvc line. Seems to reduce emmisions for some engines.
check this link ... http://www.integra.orcon.net.nz/catchcan.htm
92 SVX LS Pearl
94 SVX LSi Barcelona Red
82 Brat 4WD
Bob
Old 08-20-2007, 10:55 AM
94SubieSVX's Avatar
OOC for a while
The oil catch can thing is different, I've never heard of that.
Also forgot to add before was that before the 3rd inspection I cleaned my MAF with vinegar overnight. I don't think that could have affected it though.
bLAh
Old 08-20-2007, 11:25 AM
XT6Wagon XT6Wagon is offline
Er.... wow. that makes it seem like its running really rich.
Is there anyone who can loan you an Air/Fuel meter?
Old 08-20-2007, 11:40 AM
94SubieSVX's Avatar
OOC for a while
Not anyone that I know off the top of my head. I don't think it's running rich because around the city I get about 18MPG and highway I'm gettin about 21-22MPG. Which is about normal for the car.
bLAh
Old 08-20-2007, 01:04 PM
SubaSteevo's Avatar
No longer blue member
Subie,
Last year May my car failed for high HC as yours did (reading was 188, standard was 100).
To fix it I:
Reset the ECU to get a fresh start
Added 4oz of Acetone to a full tank of gas
Cleaned the throttle bodies and IAV
Changed engine temp sensor (had CE light for the code)
Replace air filter
Replaced MAF (had CE light for the code)
On the day of my reinspection I drove the car about 35 miles before going to the inspection station, and while I was waiting on line for inspection I kept the car in Neutral instead of park and kept the RPMs above 1k (your engine burns more efficiently that way). My car was reinspected and passed at 88 HC.
I will reinforce the PCV valve and diagnosis if yours has not been changed (mine was changed about 15k before my inspection). Considering your stumbling at 65mph the engine temp sensor might be a good idea too. Are you sure you used the proper fuel filter and installed it facing the correct way? (there's an inlet and outlet)
-Steve
01' MSM Lexus IS300
Old 08-20-2007, 10:25 PM
94SubieSVX's Avatar
OOC for a while
Originally Posted by SubaSteevo
Subie,
To fix it I:
Replace air filter
The engine stumbling I was thinking might be the TPS sensor? I haven't really tried to find that out though. And I know the fuel filter is on right, and is the right one(I got it from the dealer). Its not trowing any codes when I pull them, and the CE light isn't on at all. What exactly is acetone and what does it do?
bLAh
Old 08-20-2007, 11:17 PM
Acetone is a solvent. It's basically a fuel system cleaner. It should get any crap out of the fuel lines and clean the injectors.
Don't overdo it though. Acetone is pretty harsh stuff and your car won't be happy about being fed too much.
Supposedly it also increases mileage. Some people go as far as adding several ounces every fill up. *shrug*
Old 08-20-2007, 11:39 PM
I just read up on this thread completely. Scoring 2100+ on the HC count is unreal. My car (92, 109K miles) just went through inspection here. I replaced the primary cat with a Magnaflow universal unit when I bought it 3 months ago. Until I bought it the car had been sitting in a lot for at least 6 months, only being driven to move around the lot.
I scored 33 ppm (parts per million) at idle and 28 ppm at 2500 RPM. On a car that had been sitting for a long time, with a shadey maintenance history.
First try a private testing location. It's the cheapest way to narrow down the cause I can think of. If things are still bad I'd say a new primary cat is needed.
Old 08-20-2007, 11:48 PM
94SubieSVX's Avatar
OOC for a while
2500 RPM is the test they did for emissions all 3 times. The last time though I think the inspector was having a bad day and screwed with the numbers just to be an @$$. Also, the exhaust was the last thing I was hoping to have to replace. Since I was thinking about getting a whole new aftermarket exhaust in the future I think I might have to get it now
bLAh
Old 08-20-2007, 11:51 PM
Probably a good idea. The price Subaru charges for exhaust parts is terrifying. $700 for each pre-cat, plus the rest...I'm pretty sure you can build a full custom system for significantly less money.
Old 08-20-2007, 11:57 PM
94SubieSVX's Avatar
OOC for a while
I was checking out svxcess's setup with the ar20 resonators and magnaflow cat, etc. and was thinking about doing that since it seems like a pretty good system...with good feedback from others on it. If only I could hear it
bLAh
Old 08-21-2007, 10:19 AM
SubaSteevo's Avatar
Acetone is the active ingredient in nail polish remover. As crazy said it's pretty harsh stuff. I've been told up to 3oz is safe per 10 gal of gas, so I figured 4oz was a safe amount for our 16 gal tank.
To test your TPS you can check the voltage on the signal wire (I believe it's the white one) with an autometer. The correct reading is around .97-1 if I remember, but a search should turn up more info. The ECU reconfigures itself for the TPS reading though, so I'm not sure if that would have a big effect.
P.S. Missed the post with the 2000+ reading, that is insane!
-Steve
01' MSM Lexus IS300
