Old 06-21-2005, 07:32 PM
JoeDman79
Exhaust Options
Hey, Im new to the SVX World Network. Although I've had my 1992 SVX for almost a year and so far have replace the the tranny, radiator and the rotors with new cross-drilled's. My question is, What are my options as far as exhaust? It looks like alot of people custom make theirs, what should I think about as far as components when looking to make my own exhaust system? And is their anyway around the fact that I don't have a pipe bender? Thanks for any input.
Old 06-21-2005, 07:53 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Check out...
...Dayle's site for starters:
http://www.planetsvx.com/
as well as:
http://www.stebro.net/
-Chike
2006 Steel Gray WRX TR (sold)
Old 06-21-2005, 09:27 PM
Rotorflyr's Avatar
Sumitt also has some options that would probably work as well.
2006 B9 Tribeca
Old 06-21-2005, 11:34 PM
mbtoloczko's Avatar
sans SVX
If you are looking for performance, the first place think I'd do is replace all three of the OEM cats with a single highflow and try sticking with the OEM muffler. Magnaflow/Carsound has the greatest variety of cats. Easiest would be to use the 2-into-1 cat. I'd stick a couple of Magnaflow resonators before the cats. The tubing coming off the exhaust manifold is about 2" OD, and the tubing going into the OEM muffler is about 2.5" OD. So, you'd want the 2-into-1 cat with 2" inlets and a 2.5" outlet. I'd suggest using a Magnaflow 10414 or 14444 (stainless steel) resonator in each of the pipes before the cat. I'd put the resonators in the location of the OEM secondary cat, and I'd put the highflow cat in the location of the OEM premuffler. Try and get the muffler shop to use mandrel bent sections rather than doing crush bends on the tubing.
Mychailo
Visit my locker
