Old 03-22-2009, 12:32 PM
Black88GTA's Avatar
Black88GTA Black88GTA is offline
look like a leprechaun to me
Power mode mod...where to get pin??
I'm doing the power mode mod in my car. I'm looking for a female pin that I can connect the wire to and then snap into the connector for a solid, clean connection - I don't want to just shove a wire in there and hope it holds.
Has anyone else done this? Where did you find a female pin that fits? Other than a donor harness, because I don't have that. I was thinking maybe I could buy something at Radio Shack that might work...?
Ebony/Gray '92 LS-L, @123k - bought 01/17/2010, parked for 10 years. Getting back on the road.
Old 03-22-2009, 01:53 PM
Re: Power mode mod...where to get pin??
Pretty sure everyone has just used a donor wire from one of the harnesses that isn't used. Do a search and they detail exactly what wire is not used for anything else I believe.
Old 03-22-2009, 03:45 PM
I put female connectors from Radio shack on the wire leading to the on off switches connectors, but I bent them at a 90 angle to make them shorter when they were on. The wire to the TCU I just pushed in with out any special connector.
Old 03-22-2009, 04:10 PM
processengr's Avatar
I think a socket pulled from a pc motherboard header plug is close. I used one from a connector from motherboard sound card to cd drive.
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 03-22-2009, 05:20 PM
Hondasucks's Avatar
Subaru Technician
You can get replacement pins with a short wire pigtail on them from Subaru, every dealer should have a termininal/wiring harness repair kit they can sell you a pin out of. (If I can figure out what pin it uses, I can order a 10-pack through SPX, heck I could probably make a kit for people who aren't as mechanically/electrically inclined as the rest of us...)
1986 VW Jetta
Old 03-22-2009, 05:40 PM
Black88GTA's Avatar
Thanks everyone for the suggestions...I ended up using a pin out of a wiring harness from a burned out PC power supply. It was one of the pins on the little square 4-prong connector for P4 motherboards.
Fit nice and snug, and works great Now I just have to figure out my dash illumination issues at the switch, and I'm done...
