Old 11-28-2006, 10:36 AM
GOT2HAVESVX's Avatar
GOT2HAVESVX GOT2HAVESVX is offline
What blue lights?
Send a message via AIM to GOT2HAVESVX
Shake in the wheel ?????
My car has always drove really good with no shaking or pulling in the wheel. Today when I went to lunch I noticed the steering wheel has a little back n forth thing going on. Can anyone tell me what I might start with looking for whats wrong? TIA
Life begins around 70 MPH and stops when you dont see the flashing blue lights anymore!
Scott & Audrey's Subaru SVX's
1995 Green
1992 Black
Old 11-28-2006, 05:36 PM
What blue lights?
Anybody???
1995 Green
1992 Black
Old 11-28-2006, 05:52 PM
Trevor's Avatar
Trevor Trevor is offline
Originally Posted by GOT2HAVESVX
Anybody???
Sorry you appear to have been left in the cold.
As the vibration has only just been noticed, it could be that you have lost a wheel balancing weight. A long shot could be something stuck tight to the tread of your tyre. All in all a check on wheel balance would be in order.
Trevor, New Zealand.
Old 11-28-2006, 06:44 PM
Crazypolo95 Crazypolo95 is offline
95pologreen
Send a message via AIM to Crazypolo95
i had that same thing but when braking .The feeling that i found that was not right was that one of my front tire psi was at 29 not 32.
Old 11-28-2006, 06:57 PM
dwd1985 dwd1985 is offline
tire balance, or possibly alignment. Do a balance check first, because its cheaper. If that doesnt fix the problem, get an alignment done.
Old 11-28-2006, 07:06 PM
sharky512345 sharky512345 is offline
Send a message via AIM to sharky512345
as everyone has been saying already, check to see if your tires are balanced correctly. Also if you have been playing in the snow/mud/sand then it could have accumulated in the wheels and thrown the balance off.
Current: 2005 Black Legacy 2.5i 63k
Previous: 1996 Brilliant Red SVX LSi 117k
Old 11-28-2006, 07:10 PM
michael's Avatar
michael michael is offline
What Potholes ???
Swap the front wheels with the rear to see if it's tire/wheel related. If it doesn't change it may be suspension/brake related.
Old 11-28-2006, 10:08 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Also check if all the lug nuts are tight.
Old 11-29-2006, 11:00 AM
What blue lights?
Thanks you guys are great. Just needed a jump start! LOL
1995 Green
1992 Black
Old 11-29-2006, 11:19 AM
dannmarr's Avatar
I work for my SVX
What does the steering wheel have to do with a jump start? Anyway, glad you solved your problem.
Old 11-29-2006, 11:50 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Send a message via AIM to Ricochet Send a message via MSN to Ricochet Send a message via Yahoo to Ricochet
Mine did the same thing. When I got new tires and an alignment it drove perfectly straight and smooth.. not sure what the hell you're talking about with the jump start though.
Brian
Old 11-29-2006, 05:45 PM
What blue lights?
As in you guys were slow getting started with your answers. I am guessing it was a rock or something in the tread because it isnt doing it today.....Gonna look around under it this weekend anyways.
1995 Green
1992 Black
Old 11-30-2006, 02:37 AM
Ricochet's Avatar
I brought some ham.
It could just be from the cold hardening your tires overnight making flat spots on the bottom.
Brian
Old 11-30-2006, 07:11 AM
Mr. Pockets's Avatar
Moderator
That would have to be some rock. No, really.
You might need to get your front suspension looked at. It's possible something like a tie rod end or ball joint is worn.
Did you notice this shake all the time or just when turning the wheel in a certain direction?
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 11-30-2006, 07:12 AM
Moderator
Sounds to me like your front rotors are warped.
2005 Outback
END OF LINE
