Old 07-02-2005, 06:50 PM
'96SVXBluetiful's Avatar
'96SVXBluetiful '96SVXBluetiful is offline
You do those windows yourself?
Send a message via AIM to '96SVXBluetiful
Best Offset on wheels?
If I'm gonna get wheels that are 17 x 7.5 should i get ones with +45, +48, or +53 offset?
-'96 SVX Lsi-
-Laguna Blue-
-Haley C-
Old 07-02-2005, 09:12 PM
WGJ WGJ is offline
Stock Offset...
is 55mm., if I remember correctly, so 53 would be best.
WGJ
Old 07-02-2005, 09:37 PM
Look at Wheel Ofset in How-To Docs. Here is the Linky
Old 07-03-2005, 07:06 AM
rvnmaniac rvnmaniac is offline
Formerly known as henryrace@hotma
To me it's just 3 pics that do not tell me anything. If someone can explain what i was looking at i would appreciate it. But my understanding is the closer you keep the offset to the original 55mm the better you are. What 17" wheel was found with an offset of 53", i'd like to see those. While i was shopping i didn't see anything with more than maybe 48..........
HENRY
92 SVX Claret(No More)
12 Camaro ZL1
89 Yamaha FJ1200
07 Yamaha FJR1300
"GO RAVENS"
Old 07-03-2005, 12:22 PM
kuoh kuoh is offline
Pay attention to the location of the wheel hub surface in relation to the center line of the wheel in each of the diagrams and you will see the difference. Also, pay attention to the text under the first diagram.
KuoH
Old 07-03-2005, 12:53 PM
longassname's Avatar
Just some dude.
Significant Technical Input
Ya, that picture is actually pretty good illustration of the what "offset" means. It's not giving you #'s but showing you what offset is so you can understand what the #'s mean when you are looking at wheels. If you are shopping for wheels and you don't understand it I would take the time to look it over more closely until you do.
The basic points you should be finding out are:
1)the offset you want will depend on the width of the wheel you choose.
2)the larger the positive offset the further out of the wheel well the wheel will sit and the more likely the tire will rub the body
3) the smaller the positive the further inside of the wheel well the wheel will sit and the more likely the tire will rub something on the inside
If you are getting a 7.5" wide wheel the closer to +55 the better.
If you are getting a 8" wide wheel a +49 works very nicely.
