ATF from tranny to radiator - what's the correct path?
So I am not new here and already have done ATF cooler installations. But in the back of my mind I have a nagging feeling and the only way to get the facts straight is to start asking questions. Even though I already have done my research, it doesn't hurt to ask: what is the correct path (flow) of the ATF from the tranny to the radiator and back? I already have a Perma-cool deluxe filter and tranny cooler installed. Your feedback is very appreciated. Thanks.
Cars I've worked on: '05 Subaru Impreza STi, '02 Subaru Impreza WRX Wagon, '01 Toyota Celica GT, '98 Subaru Legacy GT 2.5 Sedan, '96 Isuzu Rodeo, '95 Jeep Cherokee 2WD, '94 Plymouth Sundance, '94 Subaru SVX LSi, '93 Subaru Impreza, '92 Subaru SVX LS-L, 2003 Subaru Baja. Last edited by seion; 08-28-2008 at 07:06 PM. |
Re: ATF from tranny to radiator - what's the correct path?
The ATF line from the transmission goes INTO the radiator on the PASSENGER side (#6 in your diagram) and OUT of the radiator on the DRIVER'S side and back to the transmission (#5 in your diagram. The original diagram in the 1992 service manual was incorrect and was later fixed in the corrections supplement. Here is the correction: Also check the How-To Document folder HERE for the various ATF flow configurations for the SVX. They include series, parallel, bypassing the stock radiator completely, and counter-flow diagrams. .
Thank you so much for the clarification. I did it right the first time but I wanted to double-check. You made me regain my peace of mind .
Cars I've worked on: '05 Subaru Impreza STi, '02 Subaru Impreza WRX Wagon, '01 Toyota Celica GT, '98 Subaru Legacy GT 2.5 Sedan, '96 Isuzu Rodeo, '95 Jeep Cherokee 2WD, '94 Plymouth Sundance, '94 Subaru SVX LSi, '93 Subaru Impreza, '92 Subaru SVX LS-L, 2003 Subaru Baja. |
If you're installing a permacool filter with a one way valve, I would highly suggest pulling off a line and having someone start the car while you watch for ATF to flow into a jug.
I thought I had it right... Didn't check... replaced a tranny after 4 days
After making sure of the ATF flow, I then paid attention the "IN" and "OUT" connections of the Permacool filter, and then I checked for warm fluid flowing into the filter and then to the radiator and then to the cooler; it all flowed like it should. Sorry to hear about your tranny, but by now you are an expert, right?
Well, I'm still not an expert, but I know that I need to double check the flow next time I install a filter
For the info of others, even if you follow the digrams posted above, if someone before reveresed the lines coming out of the tranny, it could be flowing the other way...
