idiot lights..
what do the following idiot lights indicate when they all come on simultaniously when i turn the wheel: steering, battery, stop light, brake?
-adam |
Save some money for a new alternator
well.. do you think that the fact that i'm running an underdrive pulley could have an impact on that?
i'm told that if you run an underdrive pulley, it's a good idea to do the "alternator wiring mod" which i haven't yet done.. i recently pulled my alternator out and had it bench-tested (i thought it was the culprit for a different problem) and it performed flawlessly, so i'm not positive that it's an actual problem with the alternator itself, i think it might just be that it's not getting QUITE enough "spin" from the crankshaft.. any thoughts? -adam |
The last time my alternator had problems I couldn't reproduce the problem to show what was wrong. It seemed to just act up whenever it wanted to. I had it bench tested and it was fine. They changed the voltage regulator anyway and it's been fine ever since.
i agree whith the other guys my alternator tested good and i changed it from what i read on the form and all the lights went away so id have to say its ur alternator as well
Maybe it has to do with THE TRANNY ONLY HAVIN 2 SPEEDS!!! I think the alt. is the least of your problems. But uh, yeah it's probly your alt.
