What can I expect?
What is the max amount of hp gain I might expect without forced induction or No2 using only things like cams, exhaust injectors remapping etc.?
I've seen the threads with turbos and superchargers. I'd reather invest in a Mitus 3000 Gtvr4 than attempt that |
Well you're going to first want to install the Stage 2 chip from ECUTune. This bypasses the relatively low maximum value of the stock MAF (about 250hp).
Thanks for the fast response.
And after the chip? |
I belive TomsSVX has played around with cams.
Dont stop now
Make your car breathe better. Invest in a free-flow intake and exhaust system, and use a high-flow air cleaner. I believe the cheapest hp gains come through simply increasing the efficiency of the intake, combusion and exhaust processes without force feeding the engine. With the right combination of free-flow components I think a 20-30 hp gain is a real possibility. No, that won't blow the doors off the competition but it is real power that you can use and enjoy every day.
Preston |
Cams are only good for a car that is supporting them. A free flowing aftermarket exhaust, cone intake in the fender. Stage 2v6 ECu from ECUtune aggresive grind on the cams with a nice 100hp shot on N20 and you will be flying
Tom |
Who did your cams?
Delta cams in Tacoma WA. Talk t SVXride and see what he has been working on for a new grind
Tom |
Insert Witty Quip Here... No more subie Current Cars: 96 Chevy Caprice Impala SS clone 93 Chevy Full-size blazer Soon: 2002 Honda CBR 954RR |
