Old 09-28-2008, 02:39 PM
techy101's Avatar
techy101 techy101 is offline
A.L.I.C.E.
Send a message via AIM to techy101 Send a message via Yahoo to techy101
Re: Transmission and Power Steering Problems. Please Help!
Originally Posted by RojoRocket View Post
You most likely have not damaged the pump.
Glenn
So what would be making the grinding noise if I didn't damage the pump?
ALICE: 2005 Forester XT (Ice Racing Machine)
River: 1992 SVX LS-l 125,000 # 0930 (getting fixed up at the moment)
Old 09-28-2008, 02:43 PM
The pump is just cavitating... The air is making the pump noisey. once bled all should be well
Old 09-28-2008, 02:46 PM
techy101's Avatar
A.L.I.C.E.
Thanks again for all the advice you guys. This project has been my "learning car" and this is my first time having to deal with the power steering system, so I'm kinda flying blind. I'm sure I'll be back on here when I'm out in the garage.
Old 09-28-2008, 02:52 PM
Old Fogey
Pump running dry. Manual specifically mentions persistent noise/bubbles until all air is bled, but does not have BIG CAUTIONS or the like around it. Now, if you ran it for miles making the "run-dry grinding" I would be saying otherwise. Good tip on the O-ring by gstape above BTW.
Any luck finding the correct torque wrench? Some auto-parts stores have tools for loan (Auto-Zone for certain) requiring a refundable deposit, but not requiring expense of purchase.
Glenn
Old 09-28-2008, 02:55 PM
techy101's Avatar
A.L.I.C.E.
Crap, I can't believe that I forgot to mention this... Is the little black thing that screws into the back of the PS Pump supposed to have wires coming from it? I found two wires just hanging out not hooked into anything when I first started investigating.
Again, I can't believe that I forgot this...
Either way, what is that black thing that screws into the back of the pump?
-Matthew
Old 09-28-2008, 02:58 PM
techy101's Avatar
A.L.I.C.E.
Glenn
I'll be going to the auto parts store in a couple of hours. I'd rather just buy the tool, especially because it's something I know I've wanted before, and I'm sure I'll need again. My theatre has two shows today, 2 and 7:30, so I get like an hour in between to waste. NAPA here I come. I'm going to be looking for those Helicoil things, and an appropriate torque wrench.
What size O-Ring should I get for the pump?
Old 09-28-2008, 03:07 PM
-Matthew
Thats your pressure sensor switch. It detects the pressure in the high pressure side and allows the rack to modulate it properly
Old 09-28-2008, 03:32 PM
techy101's Avatar
A.L.I.C.E.
Does anyone know the OEM Part Number for the Pressure Sensor Switch??
Old 09-30-2008, 08:44 PM
techy101's Avatar
A.L.I.C.E.
New Question...
I got three stripped messed up holes on the tranny fixed with Helicoils. Those things are great! BUT, on my last one I managed to drill the hole at an angle and the bolt won't seem to thread properly into the coil. Will the oil pan seal if it's missing a bolt on one corner?
Old 09-30-2008, 08:56 PM
gstape gstape is offline
New Question...
I bet it will
Old 09-30-2008, 08:57 PM
Old Fogey
Pressure sensor switch is PN 34428PA000 per subaruparts.com.
As far as the pan, you might get lucky without a bolt, but alternative is to go next size larger. Remove the coil and re-drill if there's enough material there. Risky business though. TT Tom. He may have another idea.
Glenn
Old 10-01-2008, 07:14 PM
techy101's Avatar
A.L.I.C.E.
Well, good news and not so good news (but not bad).
Good news is: Thanks a ton guys/gals. I got the Power Steering system up and running and it seems to be working well, but i won't know for sure until I get the car off jackstands and driving. It took four times "bleeding" the system until the pump quit making noise, but it's quite as can be now
Now for the transmission. I put heliocoils in and my new gasket came in today. I put it on and the stupid thing is leaking like a sieve. I tigntened things down a fair bit harder than you're supposed to and it slowed but is still leaking.
BUT I have a theory now. I feel silly that it didn't dawn on me earlier, but such is life. When I took the pan off the trans I noticed that the previous owner had just sandwiched a new gasket over the old one. So when I took it off there were two. The new-ish one came off pretty easily but the old one was practically hermetically sealed to the oil pan. Took about an hour of work to get it all off.
When I finally did get it clean I noticed that each bolt-hole in the pan was raised about 1-2mm (towards the transmission). I didn't think anything of it (stupid I know) assuming that since it hadn't leaked before it must be fine. Today I started to think how little sense that made, and I'm pretty sure that it's supposed to be flat. Teach me to assume things are correct.
So now I've ordered a new trans oil pan and gasket, which should come in on Monday. That should make the problem disappear.
I was feeling mentally challenged today that I couldn't seem to make a simple gasket work (TWICE!).
Hopefully the SVX will be back on the road next monday, complete with a new set of HID's.
And yet again, you guys have been such a big help!
Old 10-02-2008, 06:01 AM
good news!! Lets hope it cures the issue
Old 10-06-2008, 10:44 PM
techy101's Avatar
A.L.I.C.E.
Well There's your problem...
New oil pan fixed things right up. Unfortunately now my small oil leak seems to be worse. It's dripping off the front crossmember thing (I am not sure if that's the right name. It's the beam that runs left to right just in front of the steering rack.)
But I'll look into that tomorrow. I've replaced the valve cover gaskets already.
Anyway, here was the issue.
Old trans oil pan:
New trans oil pan:
Old 10-07-2008, 04:24 PM
oab_au oab_au is offline
Yeah no substitute to putting the pan on with a rattle gun.
One Arm Bloke.
Tell it like it is!
