Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Other Mods
Old 11-01-2006, 05:14 PM
04sti 04sti is offline
Send a message via AIM to 04sti
Rear Diff and Lateral Links
Well I just got back from the shop and we got the rear subframe bolted back in, the interesting part is that we took the lateral links, hubs, and differential from the 06 wrx and we swapped them into the svx subframe , the only modification we had to do was take the longer rear studs from the svx and put them into the wrx diff. But the front lateral links are aluminum so it should lighten it up and they will work with our setup, I will post some pics later tonight.
Old 11-01-2006, 08:59 PM
Nice!! I have been waiting to hear/see an update
Old 11-02-2006, 08:44 AM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
Send a message via AIM to gest24
Proves my theory that we can use impreza latteral links out back. Which also leads me to beleive we could also "re-engineer" some thicker rear sways from the impreza to LGT.
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs!
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
88 XT6(regret the day I left her behind)
socaleuro.com They like the flat 6...
Check My New Homepage..
Old 11-02-2006, 09:35 AM
Don't forget he is using the hub from an 06 WRX
Old 11-02-2006, 09:38 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Kerry,
Nah, just bend up your own
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 11-02-2006, 09:41 AM
SVXRide's Avatar
Question -- do the wrx lateral links have the same dimensions as the SVX pieces, or is this a case of "they'll work as long as you also use the wrx hubs"?
thanks.
-Bill (hoping the answer is "they have the same dimensions" )
Old 11-02-2006, 09:48 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Look at the rear swaybar from a B9 Tribeca. It's supposed to be huge inorder to control that vehicle's mammoth weight.
2006 Steel Gray WRX TR (sold)
gest24's Avatar
#1 6MT In Cali
Originally Posted by SVXRide
Kerry,
-Bill
Bill,
How about I just send you some $$ and you bend me some? lol
RIP
84 VW Scirocco
02 WRX
Old 11-02-2006, 10:04 AM
SVXRide's Avatar
Bill,
Kerry,
Sure, just tell me what dia bar you want. Check my locker for the one on BillStock v4.0.
-Bill
Old 11-02-2006, 05:45 PM
the lateral links are exactly the same dimension, I don't know about the bolt holes on the hub side, They are approximately the same size they might work with the svx hubs, when we do the sti swap on bdr's impreza i will see if the svx hub fits in there. The rear diff works though all you do is take the longer rear studs from the svx and put them in the wrx rear diff
Old 11-02-2006, 06:53 PM
dynomatt dynomatt is offline
Subscribed.
So the links are the same, but do the hubs/uprights bolt up to the SVX shocks?
M
Old 11-02-2006, 06:58 PM
And are we talking about an 06 WRX or an 06 STi? Or are they teh same fore you guys?
Are the sway bar mounts the same (or has somebody already asked that).
Old 11-02-2006, 08:51 PM
Originally Posted by dynomatt
Subscribed.
M
We have Tein SSPs for an 06 wrx, we have enough adjust ability and the pillow balls let us move the shock where we need it.
Old 11-02-2006, 08:59 PM
here is one more picture
Old 11-03-2006, 12:37 AM
I forgot the strut sits much further forward on the WRX/Legacy's.
I notice you haven't connected the swaybar yet...any plans?
I also notice that you've used the alloy front lateral links?
Did you see if you could adapt the WRX trailing links to fit too? They'd need to be mounted in a different spot. The SVX trailing links are about 250mm shorter I think.
The next question is what are you going to do about the front? As discussed elsewhere, it's not such an easy fit.
