Old 01-08-2003, 09:48 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Originally posted by ensteele93
If it is that safe to drink, then let me have a swig of it.
Just a minute. I need to pour off a little bit to help a member get the ink stains off his Ecsaine.
Randy Johnson
Mike Davis -- at Reading VI
Old 01-10-2003, 09:19 AM
cbx-man cbx-man is offline
For a one man brake bleeding operation, Russell Speed Bleeders are available from Jeg's for $9.99 per pair.
PT# 799-639560 10mm x 1.0 Import. These fit all other Subaru vehicles as well.
http://www.jegs.com/cgi-bin/ncommerc...59&prmenbr=361
cbx-man
'92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter
'92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft
'80 Honda CBX in-line 24 valve 6 cylinder
Old 01-10-2003, 10:13 AM
svx_commuter's Avatar
That's pretty good for a fast bleed but for flushing the master cyl would have to refilled alot. What keeps air from going past the threads?
Old 01-10-2003, 11:12 AM
Isn't that the goal for flushing the system? Pour in new fluid and pump the brakes until the new clean fluid comes out each one of the bleeders?
Backing off the threads 1/4 turn shouldn't allow air to enter past the threads, and the internal spring loaded check ball only opens when enough pressure is applied to push fluid past it.
cbx-man
Old 01-10-2003, 12:32 PM
Yes I see your point thank you.
