Old 01-09-2012, 09:46 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
oil collecting on top of motor
hey guys i have some oil that’s collecting on top of the motor between the intake manifold and motor and leaking down the back side on the driver’s side,
i don’t think its a critical issue but i would like to solve it or find were its coming from
both valve cover gaskets were replace by the previous owner and are dry as a whistle ! also the power steering pump is dry as a whistle also !
nothing around the oil dipstick or goose neck filler either
seems to be more on the driver’s side then anything
im guessing its the pcv valve? is there any external oil lines on the top part of the engine ?
any sugestions or ideas ?or pretty much bite the bullet and pull of the intake manifold im guessing ?
thanks guys
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 01-09-2012, 10:07 AM
Re: oil collecting on top of motor
That seems to be a common-ish SVX issue. Oil collects in the intake manifold and then drips out from the IRIS valve in the center. Replacing your PCV valve may help to fix the issue, but don't expect it to stop instantly (oil will continue to drip until it's all gone from the intake).
Old 01-09-2012, 10:10 AM
it seems to be a lot of oil from just the air intake track
im going to clean thar area up and see how bad it is or how long it takes to puddle up again
never had this on any of my 3 other svxes so i guess it makes the odds of 1 inn 4 LOL
Old 01-14-2012, 09:59 AM
KJC Pearlie KJC Pearlie is offline
I have this same problem with my 92. I was thinking of taking off the Intake manifold to see what's going on but I know that's a bit of work. Please post anything that you might find and I'll do same. Good luck
Old 01-14-2012, 10:17 AM
wdb wdb is offline
dances with roads
I had oil on top of my motor. I took off the intake and it was all oiled up, and the oil was dripping out of it. I cleaned up the mess, replaced the PCV and all the vacuum hoses, plus replaced the knock sensors while I was in there. I haven't driven the car a lot since then but have not noticed any oil.
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 01-16-2012, 08:14 AM
Are you sure it's oil? as the PS tank is prone to leak onto the top of the motor...
Old 01-16-2012, 07:45 PM
My manifold leaked oil, which was cured when my IRIS/some part of the manifold was replaced/operated on.
Old 01-16-2012, 09:19 PM
The oil collects down where the IRIS butterfly is. It leaks out of the shaft ends.
The question is where does all this oil come from.
No brainier, out of the crankcase breathers, both the PCV, that can be blocking, forcing it into the air delivery pipe.
Or the cam cover breathers, that block inside of the air box in front of the throttle bodies. This then forces all the crankcase gas up the inlet air pipe.
So it ends up collecting in places like the IRIS, Idle Air Valve, and the Auxiliary Air Valve, the last one, makes it blow smoke on start-up.
Fix, clean all the cam breather passages, renew the PCV valve.
Old 01-18-2012, 09:28 PM
Was just looking through my service history, and I remember the oil pressure switch leaked like CrAzAy, so crazy, I had to type it out like that to emphasize the craziness.
It's between the PS pump and alternator. Check it out.
Old 01-19-2012, 03:02 AM
IF you decide to replace the oil pressure sensor, make sure that you replace it with a Subaru one!
The part # is 25240KA040.
Old 01-19-2012, 07:37 AM
thanks for the information guys with your guys help i narrowed it down to the iris valve area and its a common issue
i just havent had time to take it apart looks like its and extensive job
every day i have a small puddle on the right side of the car area "its not from the valve covers "
if i get a flash light i can see the area where it is leaking,
can you just buy the o ring itself for the iris valve? or do you use hi temp rtv to re-seal it ? or is there another o ring where the center shaft is for the butterflies are inside the IRIS ?
i still have to find the root of the problem i was thinking of going ahead and replacing the pcv valve first but it was done from the previous owner and blowing all the lines out,
there is no oil around the oil pressure senser and none by the power steering pump area
again thanks for all your help
Old 02-22-2012, 11:14 AM
alia176 alia176 is offline
I wonder if an external oil catch can would help with the oil issue. Not sure if that would affect anything detrimentally or not!
I have the same puddle on top of the engien and my IRIS valve gasket/seal was renewed couple of years ago when I did all seals and hoses. Guess, i'll need to revisit it again
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 02-22-2012, 11:58 AM
Wikedjuggalo's Avatar
Rebuilding
Did you replace the PCV valve?
Old 02-22-2012, 04:14 PM
Out of curiousity, are you guys using synthetic oil? Since this thread I've noticed a significant amount of oil buildup in the same areas. I use Amsoil. I've always heard that going from conventional to synthetic would cause leaks, this may be the extreme result. If this is true, the effect may be compounded by the age of the hoses and gaskets...just a thought.
Old 02-22-2012, 06:36 PM
Subaru Alliance Subaru Alliance is offline
+1 for the amsoil (i love that stuff) I just put new gaskets and seals on my spare engine and didn't notice there being a puddle there but it was setting for a while before I replaced everything. I will look at my daily driver to see if it having a similar issue. If so I can reference this post to fix it.
2003 Baja Sport
1994 SVX LS
1992 SVX LSi parted out
