Old 05-11-2009, 12:57 PM
Giugiaro Giugiaro is offline
boostin to the outer space
Limitations of the hydraulic valvetrain
Hello people,
I've been around for a while now, read a lot of threads but I am not much of a poster.
I have a curious question for the mechanical gurus, what do you think is the limitation of the hydraulic system? do you think that with the correct springs, it can hold around 10.5~11mm of valve lift?
awaiting for your replies, thanks.
E.
The SVX expansion goes two ways:
1. Horizontal expansion: Multi SVXi
2. Vertical expansion: Fun max from one SVX
Old 05-12-2009, 04:52 PM
Re: Limitations of the hydraulic valvetrain
Originally Posted by Giugiaro View Post
Hello people,
E.
no. The valve will bottom out on the guide or the spring will coil-bind before you reach those heights in lift. If you are modifying the valvetrain, HLA's are only going to cause variables and inconsistancies
Old 05-13-2009, 12:45 AM
springs coilbind matter resolved.
what do I need to do with the valves? new taller ones?
E.
Old 05-13-2009, 01:40 AM
E.
How do you have the spring issue resolved, yet still have no idea on valve length?
i only ask this as a person seeking info, not as someone trying to cause problems.
blk 92' LSL w/ average mods
Old 05-13-2009, 01:56 AM
i have access to many springs sizes, mostly beehive.
i can get the valve length easily no problem. the thing is the svx valvetrain i have no experience in. my original question was to know what you folks think as experts in this car.
i am aiming to a very high valve lift in my turbo setup. i just want to know what to look at inside the valvetrain.
doesn't valve length affect the cam lift? meaning with taller valves, i cannot lengthen the lobes anymore?
wow, too late here, need to sleep, gn!
Old 05-13-2009, 10:06 AM
RallyBob's Avatar
RallyBob RallyBob is offline
Registered fabricator
The issue with running taller valves is you'll either need to gut the hydraulics and convert to solid followers, or shorten the base circle of the camshafts appreciably. A smaller overall lobe will have greater stresses imparted to it and to the cam followers.
If you are going with much higher lift than stock, then presumably the shape of the lobe is far more aggressive. A more aggressive lobe *may* run into problems with the hydraulic adjusters. There's a lot of mass there for the lobe to toss around, so you may in fact encounter some issues with valve float that you wouldn't see with a stock cam profile. Strictly speculation on my part, but be aware you may be doing a lot of R & D to find out!
Bob Légère
EG33 Impreza tweaks
Old 05-18-2009, 01:50 AM
after reading your comments here guys and talking to subaru experts who have previous experience with hydros, i realized that an agressive hydro system might work well in the beginning but later on experience problems. needless to comment about the oil pump issue.
i think i'd better go with the solid system.
thanks
E.
Old 05-18-2009, 07:42 PM
residentgearhea residentgearhea is offline
anyone have info on the solid lifter conversion? is it a matter of fabbing an item the same height as the HLA (w/ correct lash) or is there some drop in parts available?
Old 05-19-2009, 08:59 AM
search for the word "valvetrain" and you will get there.
Old 05-19-2009, 09:50 AM
Schralper's Avatar
Schralper Schralper is offline
Like RallyBob sez there's a lotta weight moving.
That's the real problem w/ hyd cam parts.
The blessing being not having to check valve clearance occasionally
Which on a street car w/ a EG33 I wouldn't wanna do. Motorcycles can be bad enuff. Or even solid roller small block chevy.
If you're into check valves go solid for more consistent valvetrain action.
Why lots more lift instead of a combo of lift and dur + increasing LSA for the boost be more effective?
I'm guessing you got aftermarket ECU, what ya running?
btw custom length s.s. valves are about $720 for all 24.
which is why I didn't go w/ then for these heads.
WFO!
http://www.cardomain.com/id/Schralper
"You all laugh cuz I'm different
I laught cuz you're all the same."
Old 05-19-2009, 11:32 AM
will be running on an MS1 and will upgrade later on to MS2.
what do you intend to do with the heads?
Old 05-19-2009, 10:27 PM
JaySVX's Avatar
JaySVX JaySVX is offline
If you're looking at megasquirt, you may be interested to talk to TomsSVX, as he had the hydra designed, it's like the megasquirt on steroids, it can do all, plus some, and is already designed for the SVX.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
