Old 05-29-2006, 03:42 PM
apollow
engine not start
i'm new to this forum, and i'm not a native english speaker. so i'm trying to describe the problem clearly.
today my 92 svx gave up starting when i was getting back from mall. i turned key to start position, the electrical works (lights on), but the engine shut up, even without any starting sound. so i called AAA for help. when it was hooked up with the towing truck, i tried last time, it started. and after that, i tried several times, no problem at all. i'm not sure what problem is. maybe the hot weather (above 85F). i am totally no idea. do i need to take it to repair shop? not sure when the problem will happen again. please help. thanks.
Old 05-29-2006, 04:08 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
thats really hard to say more then likely yes... ?puede halbar espanol?
- John
Old 05-29-2006, 04:28 PM
apollow
yes, maybe i should make an appointment with the repair shop.
i'm not speaking Spanish.
Old 05-29-2006, 07:37 PM
Manarius's Avatar
Manarius Manarius is offline
Ok, so describe the problem more accurately for me. When you turn the key the car doesn't respond? It just sits there and stares at you? Or when you turn the key the car keeps trying to start but doesn't (it just keeps turning over over and over again)? Depending on which of these it is, will determine what is wrong. I wouldn't make a repair shop appointment yet. You may still be able to save some money.
-Jason
-Obi Wan Kenobi
Old 05-29-2006, 10:05 PM
apollow
it is the first case. only the warning lights in the instrumental panel are on, which is normal, and the engine has no response at all.
Old 05-30-2006, 12:58 AM
Suby Fan's Avatar
have you tried starting it in neutral?
- John
Old 06-06-2006, 04:25 PM
SVX10's Avatar
SVX10 SVX10 is offline
Fighting with electricity
So, I'm having this problem intermittently now, also. Keep in mind I have 5MT w/WRX starter:
I put the key in, turn the key, and nothing happens except for a click (relay sound...not the chatter from the starter), and electrical components coming on (headlights, stereo, warning lights, etc.) If I rapidly turn the key 5 or 6 times in a row, it's bound to start.
Any ideas?
Old 06-06-2006, 04:59 PM
This has happened to most of the WRX swaps but is no exclusive to those. The ignition is not putting out enough power to engage the starter solenoid. The proper fix is to replace the ignition. Most people (including me) add a relay to send power directly from the pattery to the starter solenoid. Not a click in over 2 years.
Old 06-06-2006, 05:01 PM
SVX10's Avatar
Interesting...that's exactly what I'd figured. So, could you send me with a PM describing what you did? Thanks!
Mat
Old 06-06-2006, 05:13 PM
This thread will help:
http://www.subaru-svx.net/forum/showthread.php?t=25362
Old 06-06-2006, 07:38 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
As was mentioned, try starting it in neutral. Also try shifting through the gears and back to park, then try starting it.
Old 06-06-2006, 10:56 PM
SubaSteevo's Avatar
No longer blue member
Originally Posted by Earthworm
I had the exact same problem and the relay fixed it for me as well.
-Steve
01' MSM Lexus IS300
Old 06-07-2006, 08:04 AM
Mr. Pockets's Avatar
Moderator
How old is your battery? A bad battery can be misleading sometimes, because everything will seem to work correctly but the engine won't even turn over.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
