Old 05-28-2006, 08:08 AM
jeradsvx jeradsvx is offline
Send a message via AIM to jeradsvx
crank pulley woes again
car hasnt ran in a few days, yesterday changed the coolant temp sensor and when i was done i started the car up to make sure it ran, started it up for like a minute then shut it off, went out this morning to start doing the crank pulley and the bolt on the crank pulley was loose!!!!
The last day that I drove the car i know the bolt wasnt loose, cause i checked it
what i am asking is could there have been any damage caused by running it for that minute with that loose bolt, everything sounded ok
thanks
jerad
Old 05-28-2006, 08:57 AM
well i just took the pulley off, come to find out subaru gave my car the optional two peice crank pulley ha ha ha
Old 05-28-2006, 12:25 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
WHOOPS. I know how you feel as I've been through 2 stock ones now due to the bolt coming loose. So now I have an underdrive with the strongest thread locker I could find on the crank bolt. Let's see it do THAT again.
Old 05-28-2006, 03:01 PM
dromano's Avatar
dromano dromano is offline
crank pilley/thread lock
Jerad,
If the crank stayed on the key it's OK. The picture is the old pulley, right?
When I changed to an under drive pulley I used hi temp thread lock and torqued to spec. The only problem is the thread lock has to be heated to 500 degrees to break the lock Are you up and running?
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 05-28-2006, 03:33 PM
yeah, everything is back on and up and running good
thanks for all your help again dave
