#31
Trust your nose.
If the engine has dropped oil pressure, and seized or tightened up, the oil that was between the seizing surfaces, will be burnt. Take the filler cap off and smell the crankcase. If it smells burnt, it is. No burnt smell, it may be ok.
#32
Dave,
You might want to go ahead and drain the oil -- this will allow you to do two things at once --1. smell it to see if it's burnt (per Harvey's suggestion) and 2. see if there's any antifreeze in it (to see if you've blown a head gasket) -Bill p.s. you might want to hook the starter back up and start the engine to see what happens with the TC disconnected
#33
The starter ring is on the TC, so you can't start it with the TC unhooked.... I'm betting it's a tranny/TC issue
#34
There was no coolant in it, and I saw no gunk in the radiator or tank. I'm filtering it through a rag to see if I can come up with any metal particles... p.s. Thanks for that other tip
#35
-Bill
#36
Good News!!!!!
At the bottom of the oil pan I found "Gold Dust" I figure I can sell this dust to help pay for the new engine ... So this brass is a bearing I guess?? Time to lift the block and drop the pan? Or should I just plan on replacing the engine?
#37
You can probably replace the engine cheaper than repair that one....
#38
eeeeeeeewwwwwwwwww main bearings.... Nasty failure and very expensive to replace. I would say you found your problem
Tom |
#39
And found us a good source for an engine to build. What did you ever do with that hunk you killed Tom?
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
#40
the block is still in the basement. Heads I gave to Bill at the Challenge. Still trying to find a cheaper source for main, con rod bearings pins rings etc... I would love to build the block for 9.0-1 CR for the turbo project but I need to find bearing that won't cost $1k for just con rod and mains
Tom |
#41
Fixed your post. -Bill p.s. now I see why you sent Dave off to Florida...you don't want him driving the Race Car!
#42
#43
Really? I figured Dave was just going down to Disney World You know, we could probably work a deal with the 275s so they show up on your "official" books in a benefical manner -Bill
#44
#45
