Old 04-20-2003, 04:19 PM
phoenix96's Avatar
phoenix96 phoenix96 is offline
SoCal SVXer
Send a message via ICQ to phoenix96 Send a message via AIM to phoenix96 Send a message via Yahoo to phoenix96
Bad Bearings - in the front?
Has anyone had front wheel bearings go bad? I replaced the rear bearings 6 months ago, but lately I've been hearing what sounds to me like a bad bearing, but coming from the front of the car. I haven't heard of anyone else's front bearings going bad in the SVX.
phoenix96
2006 Legacy GT Limited · 2006 Outback 3.0R VDC · 1992 SVX LS-L
Old 04-20-2003, 04:21 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Re: Bad Bearings - in the front?
Yepp. My moneypit FWD 94 had bearings that were changed on all 4 wheels!!!
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 04-20-2003, 05:08 PM
Any bearing can go bad. Statistics for the SVX show most bad bearings being rear bearings. My only experience is a right rear, done recently. Can currently hear a barely audible growl, don't know if is the same wheel, the other rear, or one of the front bearings.
If your car has over 60K, it would be good preventative maintenance to "open" the seal on each wheel, top up with the correct grease, and re-torque with a new and pretty cheap outer seal. I reckon the main cause of failure is distorted seals letting the lubricant away, with a lot of heat from the rotors then speeding up the process of destroying the dry bearing.
Old 04-20-2003, 07:26 PM
svxstl
bringing mine in tomorrow for a left front bearing! i wonder if i can just have my paychecks direct deposited at the shop
