Old 09-22-2007, 09:30 PM
black beast black beast is offline
Back Road Blazer
Send a message via AIM to black beast
5mt HIGH acc. shake
Hey all,
OK I have noticed this for sometime and have always said "O the clutch of the little WRX cant hold the extra power of the 6 cil, not to mention thje other mods I have done with it...
But when I had a co-work ride it under the idea that he could ride her better then I could he too felt it, and he thinks it is a crappy tranny mount in the rear. Which when I think about about it, makes more sence to me, as the clutch is in the front and the sound and the bounce comes from the rear.
The bumping sinsation comes under hard acceleration and only when leaving first gear to go into second. No matter how hard I shift into third or forth I can not recreate the problem it is mearly a 1st to 2nd deal.
The bump makes the whole car lurch.. gladly I know when it is gunna happen so I can control the monster...
Is it a real tranny mount that has rotten, or is it something else. BTW the exhuast system is tight, and I tired to make it move and it will not so it is not exhaust vibration.
-Chris
'94 ebony pearl, with orange "silicone" hoses, painted beauty cover, Tom's Intake, Dayles Cold air intake; with HKS mega suction foam air filter, 3in header back exhaust, STI ground wires, euro front fascia, euro front grill, reactive 17in wheels, Nitto Invo's, Drilled and slotted rotors, stainless break lines, Koni strut inserts, Drop springs, 5MT, shotshifter, Clutchmasters clutch, ACT prolite flywheel, EL Glow gauges, The ECUTune stage 2. To Do: Cams, port and polish, etc.
Old 09-22-2007, 09:50 PM
Speedklix's Avatar
Locker Link Solution
probably just an improperly balanced or simply not balanced driveshaft... I just chased down a problem with mine doing it after who knows... anyway I cured mine with trial and error using some stick on tire weights.
I'll probably pull the whole thing and have a new one made using my modified one as a reference.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 09-23-2007, 12:01 AM
ridered777's Avatar
ridered777 ridered777 is offline
Finally HAS a 3rd pedal!!
Send a message via AIM to ridered777 Send a message via MSN to ridered777 Send a message via Yahoo to ridered777
I would only suggest the drive-shaft if he has a different center diff installed... didn't read your mod list, so are you running a rear-bias? If so, I SUPPOSE it could be the drives-haft... Speedklix usually knows his stuff.
If its a high intensity only though, I would suppose a problem with the suspension/drive-train combination. A mount, I would think, would not be enough to cause a noticeable problem. Though I could be wrong. Perhaps the CV axels in the back, or the rear struts? I'm mildly puzzled, and the descpription isn't the greatest. Though we both live near you, perhaps we could look 'er over... I met your brother by the way, you need to check the US forum-> NE forum -> NH sightings thread.
-Craig
94 LSi 5spd Barcelona Red, 14Xk miles.
Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior.
(up next) Full cage, fuel cell, 327 swap
Old 09-23-2007, 11:26 AM
It could be the rear diff mounts too, as right now I'm running a 5-speed rear wheel drive set up, and the rear diff ISN"T mounted firm enough to absorbe all the torque of the EG33, and I can feel it give and hit it's limit of movement when launching very hard(but the rear wheel burnouts are pretty cool)
I need to work on stiffing up it's mounting system...
But I'll be going back to AWD soon....so may not be a big deal then.
Just another thought on it.
Old 09-23-2007, 07:00 PM
There is a HUGE tq transfer between 1st and second gear. I'd suggest taking a good look at the strength of your trans X-member and make sure it is not shifting around or flexing too much... Also it could be a clutch issue
