Fuel pump assembly minus fuel pump
I need a fuel pump assembly minus the fuel pump. Mine is in bad shape, and I don't think you can by this by itself. Unless someone needs a pump without the rest of the assembly, then maybe we could buy the setup together and swap for the parts we both need. I'm also looking for the electrical connector that connects into the auxilliary air control valve. Anyone got one in good condition?
Thanks Chuck D.
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
This?
Yep
Yes sir. Mine is all nasty and corroded. If I can't get one quick I will probably just sand and clean mine up a bit for reinstall. I am ordering the right and left side level controls (which have not been working for years) and the clip. The pump assembly is a bunch of money, so if someone removed one that is in pretty good shape still I will buy it. The one you show in the pic looks a little corroded?
By the way, thanks for putting all the fuel pump info in your locker. It has been really helpfull. While I'm doing all of this, I'm also going to install a walbro fuel pump. Take Care Chuck D.
One other thing
The framework you used for the walbro install looked a lot cleaner than what came out of the tank. Did you do anything special to prep the surface? Or was this a new frame? Were you just able to buy the frame without the fuel pump? I used a wire brush and some parts cleaner, but it still doesn't look too good. Don't want stuff rusting off into my gas tank. If I get the cap and the pump assembly I mine as well just purchase the entire tank assembly and sell the pump to a fellow SVXer in need.
Thanks Chuck D.
Thread Tools | |
Display Modes | Rate This Thread |
