Old 04-29-2005, 12:35 PM
mikecg's Avatar
mikecg mikecg is offline
Send a message via AIM to mikecg Send a message via Yahoo to mikecg
Speed Ometer Question for 5-speed
OK, heres the story. Im putting a 93 Legacy 5-speed in the 92 SVX. I have the tranny in, the clutch pedals, and the new x-member. THe drive shaft is currently being made for it. I desided to scrap the 2 piece and have a single one made for it. Next is the rear diff. I was going to start on the conections for the tranny and while looking at it I realized the Legacy used a cable driven speedO while the SVX uses an electronic. Has anyone found a way to work out this problem?
Old 04-29-2005, 12:54 PM
Unscrew the SVX's Electronic speed sensor and screw it into the Legacy 5-speed's cable opening.....wha-la it's solved.....but you will have to splice a section into the wiring harness, as it won't reach back to the location on the 5-speed....
Old 04-29-2005, 01:32 PM
Earthworm's Avatar
Meow!
Mine reached!
(but I cut the grommet in the firewall to give it the extra slack it needed)
Old 04-29-2005, 03:50 PM
mikecg's Avatar
What about accuracy with the 4.11 gears?
Old 04-29-2005, 04:21 PM
Earthworm's Avatar
Meow!
If you're referring to the speedo being off...it won't. The speed is taken from the front diff so it will be accurate.
Old 04-29-2005, 10:38 PM
svxpert svxpert is offline
<<THe drive shaft is currently being made for it. I desided to scrap the 2 piece and have a single one made for it.>>
good luck with that! they are made in 2 pieces because of the angle of the tranny and rear. your not going to have the right angle.
