Old 04-25-2003, 05:05 PM
Driveshaft Question
I have a 92 ls-l and was wondering if the drive shaft was one single piece or a two piece. Thanks
chris
Old 04-25-2003, 05:39 PM
wawazat??'s Avatar
wawazat?? wawazat?? is offline
Yeah, I'm still around
It's probably a single piece. The easiest way to check is to climb under the car and look at the joint under the heat shield above the reesonator. The two piece designs are bolted together near the carrier bearing.
Todd
Down to none
Old 04-25-2003, 06:40 PM
Earthworm's Avatar
Meow!
So which SVX's had which driveshaft and when/why did they switch?
