Old 02-25-2010, 10:02 AM
mbrady mbrady is offline
Picked up our first SVX
My husband and I picked up a green '95 SVX L AWD for our 2nd winter car/DD. It has 168k on it. The hood has to be held up, the trunk doesn't open (might be frozen shut), the steering wheel tilt feature doesn't work (it won't lock into place), 3 of the struts are bad.
We are gonna do a service on it: t-belt, other belts, pullies, water pump, t-belt tensioner, tranny flush.
What brand transmission fluid is best? Where is the best place to find struts?
Melissa
Melissa
1995 Dodge Stealth Twin Turbo (1 of 553)
1996 Dodge Stealth R/T (1 of 115)
1995 Subaru SVX L AWD
1995 Subaru Legacy/Outback L
Old 02-25-2010, 10:19 AM
dbarnblatt's Avatar
Re: Picked up our first SVX
Congrats! A few quick fixes:
Hood:
new struts are available for the hood. A subaru dealer can get them... might be costly.
Trunk:
You might have the valet key. Will the key open or lock the glovebox? If not than have a regular key made and you can get into the trunk. The latch on the trunk also may be locked to prevent it from being opened from within the car... have you tried the trunk release to the left of the driver's seat? Once you get the trunk open make sure the latch lock is not set and you can open the trunk from within the car.
Steering Wheel:
There are 3 controls for the steering wheel adjustment. The one most people confuse with the up and down adjustment is called "lift"... just to the left of the steering column. That is used to get in and out of the car easier... pull it towards you and the wheel will lift up. Pull the wheel back down to lock it into place. That adjustment lever is located under the steering column.
Struts:
Not good news here. The options are few. Factory struts can be had, but the consensus is that they have been sitting at the Subaru parts warehouse for over a decade and are starting to go bad! One solution is Koni strut inserts, which I have done. Expensive... probably over $1000 after installation. Another solution is custom made coilovers... and you can more than double that $1000 figure.
The service is good... keep us posted!
We are gonna do a service on it: t-belt, other belts, pullies, water pump, t-belt, tensioner, tranny flush.
Melissa
Old 02-25-2010, 10:59 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
If you only want to make it driveable, you can buy used parts including struts. They need to be fairly local though or shipping will drive the costs up for heavy parts.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 02-25-2010, 11:05 AM
AS far as the hood goes, my husband said he'd just use a broomstick to hold it up. The place we bought it from had the front left strut replaced earlier. The bad struts are just annoying and not really first on the list. We looked at the steering wheel really good. The telescoping part works, but the lever that should lock the wheel into place (up-down wise) doesn't lock. The trunk release by the seat doesn't open the trunk, and the key won't either. We'll keep looking into it though. The sunroof also doesn't work. It doesn't even make noise.
I know the front rims are on backwards, we'll fix that soon....
here is a pic:
Melissa
Old 02-25-2010, 11:37 AM
In that picture the sunroof looks like it may be aftermarket rather than factory.
Nice car!
Old 02-25-2010, 11:59 AM
Melissa,
It looks like (especially for Minnesota) that you've picked up a fairly clean example.
OEM or aftermarket strut inserts (Koni) are your only real options for struts.
This car looks familiar, similar to one Ive seen in PA. Could you post the VIN in the registration thread?
Congratulations, and Good Luck with your new purchase.
Old 02-25-2010, 12:14 PM
It was a Texas car for 8+ years then it was in Wisconsin for 5+ years.
VIN JF1CX3358SH100410
The sunroof seems to be factory. It has a built it control for it and has a sliding cover.
Melissa
Old 02-25-2010, 12:44 PM
Melissa,
This particular sunroof seemed to be a popular dealer add-on. I had seen it before on other SVXs. It's a practical addition to the L-AWD offering. Note: All factory installed SVX sunroofs are sheetmetal and not glass.
Also, I highly recommend AMSOIL Automatic Trans Fluid.
Old 02-25-2010, 12:58 PM
I didn't know that............good point.
We'll go with the AMSOIL fluid also....
Melissa
Old 02-25-2010, 01:01 PM
+1 for all Amsoil fluids
Old 02-25-2010, 01:31 PM
lhopp77's Avatar
Mobile 1 synthetic is fine. Amsoil is over priced. Just make sure you get the right type. Powersteering uses the same fluid as the tranny.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 02-25-2010, 03:17 PM
NeedForSpeed NeedForSpeed is offline
Melissa
Hi,
If the trunk doesn't open when release by driver seat is pulled, it is due to the lock switch on the latch. Open trunk with key, then flip switch on latch, then you can open with floor release lever.
Same goes with the rear seat. The interior release is under back passenger headrest. If the seat will not fold down, it is due to another lever on the seat back that can be accessed from trunk. Let me know if that helps
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 02-25-2010, 03:53 PM
Gamesy's Avatar
Gamesy Gamesy is offline
maybe there's something hidden in the trunk if you havnt looked inside yet :P
Old 02-25-2010, 04:36 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
AWe looked at the steering wheel really good. The telescoping part works, but the lever that should lock the wheel into place (up-down wise) doesn't lock.
Did you find the other lever? In the middle underneath. You have to feel for it.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
