Posted this QuestIon a bit back, regarding low level shifts
Ok, my car is in the shop, under warranty and having them look at the 2 problems with the tranny, the 3rd gear shift, which they say is normal. What it does is if I'm in 3rd and let off of the gas, it drops to 1000 rpm and sits there, then when I push on the gas, it revs up to 3000 rpm, before cachunking and engaging. The tech guy says that that is normal, doesn't sound normal though.
The other thing which he thinks is a brake problem, and I believe otherwise....is that when the car is going slower than 5 mph, and usually most noticeable in reverse, is that it has a slight braking action. Feels likes I'm pumping the brakes while going backwards or slowly forwards. I figured it would more than likely have something to do with the tranny, but thought I'd check with you guys to see if you've had similar experiences or any suggestions? Thanks in advance. |
