Urgent help needed, coil replacement
Hey everyone. I have taken the coil for plug #6 off and now I'm not sure how to unplug it. Do they just pull straight out or are there clips? (I'm talking about where the end of the coil plugs in, not where it attaches to the spark plug)
Sorry if that is hard to understand as I don't know the correct terminology |
Re: Urgent help needed, coil replacement
narrow blade screwdriver helps, there is a clip that you have to unclip to detach it from the harness
-Bill
Thanks, Fun173 Last edited by fun173; 09-02-2015 at 11:50 PM. |
Here is a picture of the thing Im trying to remove. Could someone please help me identify which clip i need to pry on to get this thing out
Thanks alot for all the help, Fun173 Last edited by fun173; 09-02-2015 at 11:51 PM. |
You need to gently pry that outward as you pull the plug away.
Yep, what Dave said.
-Bill
Ok,
I have put the car back together for the night but I will take a crack at this again tomorrow. I was surprised how easy it was to remove the coil from the spark plug. I was expecting it to be easy to unplug but hard to remove from the spark plug but it was the other way around! After doing all this it does not seem too hard to change the plugs but I don't have to worry about that for a while since i had Subaru change them a couple of months ago. Thanks again, Fun173 Last edited by fun173; 09-02-2015 at 11:51 PM. |
Is this where we need to pull the flap out on each connector? I ended up getting a long screwdriver with a bent nail and have no problem pulling this flap out but the blue connector won’t budge. It works fine on the passenger side but none will budge on the tight driver’s side where of course we need it. We have around 6 hours into this and can't get this out. It was very easy to get the coil away from the plug but getting it unplugged from the harness on the driver’s side is a nightmare for us. I don’t want to try force until I am sure this is the only flap.
Does the clip which slides into the metal holder need to be touched? Thank you very much. Last edited by Happy; 04-17-2011 at 12:54 PM. |
