#91
Re: Camshafts for the EG33.
Harvey/Bazza,
Bazza's cams look to be the next step up from the ones in my car - which I will get on the dyno soon now that YT has installed the Hydra in my car! - and I was wondering what you thought about how the lobe profiles compared since we're both running stock lifters/springs/valves. Cheers! Bill
#92
My cams don't like idling below 950 rpm although I'm running huge overlap -I did get it idling nicely below that but it's to time consuming getting it perfect (have to add custom timing and fuel values into the ecu and then tune each one) - and it's a track car so f that |
#93
Bazza
Thanks! Did you get my PM? Bill
#94
The cams that you have are 257* duration and 8.75mm lift? You won’t get more lift, and the duration is as much as you can run at the rpm that you use. If you want to get a bit more up top, you can retard the inlet a few degrees, to run a bit higher. The problem is that nobody has put a degree wheel on the engine to see what the timing of their cams are, so trying to improve what we don’t know is just a guess. If you are changing the timing, you do need to know what is was. I thing I suggested that you do that, some time ago. Harvey.
#95
M Last edited by dynomatt; 10-30-2012 at 07:35 PM. |
#96
Yes I remember that you did that with the first engine. What I was getting at is if we knew where Bills cams were timed in the engine, we could look at moving the lobe centers to run higher. Don't have to get new grinds, just relocate the lobe center, by one way or another. This where we do the fine tuning that pulls the best out of what we have. Like re-time the inlet 2 teeth retard, and the exhaust pulley 1 tooth advance. to give the later closing of the inlet and earlier opening of the exhaust, and trim it up with offset keys. Harvey.
#97
Harvey,
The ones in RacerX's EG33 are installed straight up. Sounds like I should just get another set ground and look to install them as you've recommended? Thanks. Bill
#98
Tell me some of the details about the car, like what trans and diff ratio, is it only used for Auto-cross? What is the rpm range that you use? What is the lowest rpm that you use to accelerate out of a corner? What is the highest rpm that you would normally use? The engine torque has to suit the use the engine is to do. Harvey. Harvey.
#99
Right as rain! 1. RacerX now has a Subie 5 speed manual with an STI 3.90 posi rear (yes, a real posi, not that viscous attempt that the stock SVX comes with). Primarily autoX with an occasional 1/4 mile gallop ;-) 2. idle up to redline 3. there will be cases where I will need to step on the brakes, come to almost a complete stop, and then immediately accelerate (probably the biggest difference from running a track event) 4. Let's figure on ~6k rpms Thanks in advance for your help!! Bill
Retired NASA Rocket Scientist Most famous NASA "Child" - OSIRIS-REx delivered samples from asteroid BENNU to Earth in Sept. 2023 Center Network Member #989 '92 Fully caged, 5 speed, waiting for its fully built EG33 '92 "Test Mule", 4:44 Auto, JDM 4:44 Rear Diff with Mech LSD, Tuned headers, Full one-off suspension '92(?) Laguna, 6 spd and other stuff (still at OT's place) My Locker Last edited by SVXRide; 11-01-2012 at 06:02 AM. |
#100
Bit of tuning today and my cams are working a treat - positive boost at 2250 rpm and above that its instant boost, full boost seems to be around 3400 rpm. My link plus Ecu is map based and required a heap more fuel from vacuum to full boost which shows airflow (read power) has increased quite substantially - although given how bad the stock cams are tis not suprising.
Hitting the track tomorrow after a huge amount of work to get the car sorted but it does have a chance of getting close to the old subaru lap record so shall be interesting. I have vmax in the main straight from all my old setups to use as a reference for power - have to do a about 100 laps first as a shakedown and to run in the bearings. Then it's boost, full rpm and see what happens. |
#101
Looking forward to videos of the experience! Would be great if you could datalog what the engine is doing. Cheers Bill
#102
Anyway note these regrind cams vs the piece of crap rubbish stock cams, you can see the stock cams just die and acceleration drops off. These regrinds of mine just keep accelerating all the way to the limiter I had set for today. This is G force longitudinal data log. Also Vmax with stock cams at 14 psi was 195 kph. Vmax with my regrinds @ 7 psi was 192 kph running 100 RON and about 4 degrees less timing and rich AFR's for safety (since I ran out of E85 very early on while sorting out the brake bias) - quite amazing. Last edited by bazza; 11-02-2012 at 07:11 AM. |
#103
Looking good! How did the AFR track with the G force longitudinal data? Cheers, Bill
#104
In December I'll also open the taps and see what she really does at high boost - few little niggles to fix first. |
#105
Winton Flyby from Friday: http://www.youtube.com/watch?v=gAMuc-DJYhM
