#76
Re: Camshafts for the EG33.
Great, thanks
My apologies for being "off topic", but.... Do you know how the base map is modified thru any potential adaption ? Which issues have an effect? Can these learned issues be accessed with romraider? I have an "issue" which seems to go away (for quite a while) by resetting the ECU. See http://www.subaruoutback.org/forums/...when-cold.html Thanks, Tapani |
#78
Something we discovered a few years ago with the early 6MT's is that after a while the neutral switch bushes in the box became worn. This had the effect of disabling the AVCS, however it never really gave a code. People were doing all kinds of crazy things like changing the AVCS solenoids, filters and drilling holes and ****. However it was only one day when someone logged the neutral switch that the issue was found. So my advice - log every single switch you can log. And see if you can find a switch or something that is mean to be on or off but isn't. Or if the gearbox shaft speeds are jumping etc. I can't really read those logs sorry but you may find your gearbox could be doing something as basic to fix and as crazy. The fix btw was to solder to bypass the switch and cut the wires. Fix two (hard) was replace the switch which mean dropping the box. |
#79
Ok, thanks
I think I have read that the 5EAT neutral and "P" selections affect quite a number of ECU functions, including the cam timing. There's a ton of switches, both in the ECU and the TCU. Have to learn more :-) Thanks again, Tapani PS The engine behaved normally this morning and the tranny shifted up to third in mid uphill ! All this after ECU reset. |
#80
Oh, I have romraider and the freeSSM - both work like a dream.
Have not tried to pull the maps yet, though - just logging and resetting. Thanks, Tapani |
#82
#83
In the graphs posted on the Outback forum the lift was "off" for the first test. I guess the revs did not go high enough. I'll do another graph if you're interested, I have the data. Br, Tapani |
#84
Did a few runs down the road tonight... easily hits 7000 rpm nicely and doesn't fall over like the stock cam did.. sounds AWESOME!!
Torque is a little dissapointing but good at the same time - it's pretty much dead flat and just pulls and pulls and pulls all across the rev range and just doesn't drop off from the moment you stomp it to redline. And I did like the big old WHACK in the back as the turbo spooled up on the small EJ engines and threw you into the back seat but then again I changed to an EG engine in to improve the throttle control at the racetrack and torque etc. So it would seem my custom grind is going to work nicely. I think I managed to get the base circle perfect - the engine is dead quite (no clearance between lifter and cam) - just works. I'll be testing soon at the track and then will be able to provide a rough dyno plot based on G force acceleration. |
#85
If you are not getting a WHACK then you have a issue, it could be any one of a number of factors but somthing is holding that engine back. Have you swaped the guage over to make sure you are getting the boast you think you are? Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#86
Nah mate - it's how it works with a big engine (EG33) / small turbo (GT35R). I've improved several things and with the nice new cams now flowing a heap more gas - it's providing a far more linear power delivery, hard to explain unless you've driven a couple of soobie turbo setups. Basically it's just not laggy at all - and is proving linear power across the board as I planned it would and that's why it doesn't feel as fun. You should see the video... NUTS lol. Last edited by bazza; 10-26-2012 at 06:06 PM. |
#87
Hi Bazza,
Just to keep up to date on your efforts, your EG33 is now running intake and exhaust cams with the following durations: Inlet: 270 advertised 220 @ 50 thou 7.9mm lift Exhaust: 275 advertised 220 @ 50 thou 8.7mm lift with stock hydraulic lifters, valves, and springs, correct? Thanks. Bill
#88
Bill, I'll confirm shortly.
Sound clip - 7300 rpm limiter... 7 psi ish... madness haha http://www.youtube.com/watch?v=G85meSWidvw Last edited by bazza; 10-27-2012 at 07:28 AM. |
#89
Bill - my cam is this, with stock hydraulic lifters and stock valve springs. rev's alright as you can see from video above.
Inlet: 270 advertised 220 @ 50 thou 7.9mm lift Exhaust: 275 advertised 220 @ 50 thou 8.7mm lift |
#90
Wicked! Love this kind of madness!! What are you running aft of the downpipe? Bill
