Old 06-29-2010, 04:18 PM
SP-X's Avatar
SP-X SP-X is offline
TripleTwo Workz
A/C Compressor Clutch noise
Hi everyone, now that its "summer" in Canada (July-August), I've got my 97 LSi (165kms) back on the street, and have missed it alot during the off season.
One issue has come up while driving over the last few weeks, when hot outside, 22-30 C, I start the car, Auto Air control on, everything seems normal, but after about 20 seconds, I get this high pitch squeal once the a.c compressor clutch engages. Turn the air off, noise goes away once the clutch disengages.
Has anyone ever had an issues with a slipping compressor clutch assy? Everything worked fine last season, and I'm now wondering if you can even purchase a new clutch/pulley assembly, couldn't find one on Subaruparts.com.
Thoughts??
If it ain't tight, it ain't right.
1997 CDN Ebony LSi, #426
Old 06-29-2010, 04:29 PM
ZMan's Avatar
ZMan ZMan is offline
Re: A/C Compressor Clutch noise
A loose belt can have the same symptom.
Make sure it's tight enough, and if your not sure, tighten it some and try it.
Old 06-30-2010, 05:21 AM
dcarrb dcarrb is offline
Could be the belt's badly worn or loose; could be the compressor's trying to bind-up.
I don't believe the clutch assembly is sold separately. You can find a reman compressor online for around $250 U.S.
dcb
Old 06-30-2010, 12:30 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Tighten the belt first, then get some belt conditioner to spray on there, you wont hear another sound from it again.
Old 06-30-2010, 04:25 PM
SP-X's Avatar
TripleTwo Workz
Thanks for the input everyone. I put a new belt on last summer, and I'll bet that it has now stetched a little as it wore in, and gets even looser when it's hot outside.
I'll tighten it up and see what happens. I've had this problem before on other cars, but only in the winter. It does make sense that the same thing could happen when hot.
Old 07-03-2010, 10:17 AM
SP-X's Avatar
TripleTwo Workz
Belt tightened (was only slightly loose), noise gone, a/c performance is excellent.
Super easy fix, thanks for the input all. I was overthinking this one, but it's all good now.
Old 07-03-2010, 07:56 PM
kwren's Avatar
kwren kwren is offline
Belt conditioner is not for planet earth
Keith
Old 07-03-2010, 09:46 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Keith
Which planet would you suggest it be used on?
Old 07-04-2010, 01:04 PM
Are the belts meant for Planet Earth?
