Locked in my Car
Help I locked my car went into the store and when I came out I could not un lock it. I climbed thu from the Pass side when I got home the door will not unlock from inside or outside. If I put down the window turn the key to un lock pull up on the inside unlocker and pull up on the out side door handel it will open. Any suggestion seems like something slipped. Auto door lock remote is shot. Gona put it tech alao
You need to remove the door liner: 5 screws, two at the front of the door, two in the armrest pocket under the felt, one under a plastic flap under the inside door handle. Then pull the panel outwards and the bottom and slide it upwards.
I suspect that either one of the linkages has come away from the lock or the motor has stopped in a half-open-half-closed position (this can be due to water inside the motor or bad contacts). |
I replaced the fuse it unlocked ,now it won't lock. No noise when I turn the key and the inside lock is stuck. I will try the fuse again.
It is now in the Tech forum.
Still something wierd is going on. I got locked out again. seems that if I remove the fuse and then replace it, I hear a click sound and then the rurrr sound of the door lock and the locks work. I operate them 10 time or even 20 times, no problem then the next day I go to unlock the car and nothing happens. I am back to Square one.
If I put in a remote starter with door lock feature will this still happen? Last edited by Conn SVX; 06-18-2005 at 07:44 PM. Reason: typo |
I have an aftermarket entry/starter and unlocking my doors with the key is impossible.
Not sure why.
