Old 03-17-2005, 07:33 PM
lee lee is offline
Question Unusual rough running problem
Last Friday filled up (w/93 octane) at a Chevron station where I frequently buy my gasoline. Drove home (about 8 miles) and parked the car overnight. Didn't drive it again until Sunday morning to make the run for the newspaper. Car stumbled/shuddered pretty bad. Thought maybe I got a load of bad gas, so since then I have put in a bottle of Techron and 2 qts of toluene. Running better but not right. Here's what it's like today....
Once up to speed, and on flat ground (like there's any other kind around here), the car runs fine, don't feel any engine misfires. When at about 1/3 to 2/3 throttle there is some stumbling. When at WOT, there is sometimes a surging sensation - where it changes from full-strength acceleration to something less- still relatively smooth, but down on power.
Does this during "first run of the morning" cold to fully warmed up - but cold is a bit worse.
Just filled up on my way home today with Shell V-Power. Only drove about a mile to the house, and it's parked until I go to work tomorrow.
Interestingly, I normally get about 19.8 mpg. I drive a pretty standard route to/from work up & down Hiway A1A. The mpg for this tank while suffering the performance issue - 24.2 mpg!? It wasn't babied either, I accelerated harder than normal to avoid running in the middle throttle position and getting all that misfire.
No check engine light, no hard starting. Haven't yet checked anything except battery ground.
So,
Old 03-17-2005, 07:54 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
So,
Lee,
given that when you put in the techron and toluene it ran better and you're experiencing surging, I'd take a look at the injectors and/or the fuel filter.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-17-2005, 08:11 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
All 6?
Are you sure it is hitting on all six cyl? Mine was somewhat like that and one of the coils was bad.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
(+6 with other members of the family)
FREEDOM IS NOT FREE
Old 03-18-2005, 11:24 AM
lee lee is offline
Assuming my wife gives me some time this weekend I'll start checking.
I have been assuming it was fuel related since it did get better with the cleaner additions. The fuel filter is only about 10K miles old (like that means anything) - but since it actually runs better under WOT, which would mean highest flow rate, I'm doubting the filter.
I wonder about a bad sparkplugs/coil, again since it gets better under WOT - but then I always learn new things - can they behave in this way? Plugs are Bosch-4, about 25K miles old.
Idle is fine, more or less OK at WOT, poor at mid-throttle. Note, this is throttle induced and is not speed sensitive, I can get the shuddering/misfire if at 15 or 50 mph. Also noted today that if I give enough gas to cause it to start, then back off a little, then give a little more (past where it would have been an issue) it seems to work OK. Using this self-induced kind of surge - press, slight release, press some more, repeat - I can almost totally avoid the issue.
Old 03-18-2005, 12:38 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
I'd begin by checking the TPS. If it's o.k. try disconnecting the EGR valve and drive to see if the problem remains. If it goes away let me know.
Old 03-21-2005, 04:11 PM
Amazonparrot's Avatar
Amazonparrot Amazonparrot is offline
Now with Colder Air!
Send a message via AIM to Amazonparrot Send a message via MSN to Amazonparrot
Argh!
I have also been having this problem off and on for just about a year now. I have been watching over that great period of time for any number of consistant circumstances, but have found almost none. It may go away for weeks, and then come back full force, sputtering popping and shuddering that it takes forever to attain 40mph. When I took it to a mechanic to just get analyzed, he said it was the number 3 or 5 cylinder (second and third from you on the passenger side whilst facing the car). I guess it made total sense, being that if the rubber "insulation" around the coil pack was bad that it would ground somewhere and cause that cylinder to misfire. But if this was the case...then wouldnt it be persistant? And also, (and maybe its like a placebo effect) it seems like sometimes when i fill up after being empty that it gets worse for a little while, but there is really no telling b/c its so random (also I just changed the fuel filter less than 2k ago, or at least Chike did it for me...haha)
-Andrew R.
Pitch us some help here!
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD*
2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp).
Charlottesville, VA Represent! (voted #1 place in America to live!)
http://www.subaru-svx.net/photos/user.php?Amazonparrot
Old 03-23-2005, 01:16 PM
lee lee is offline
I finally got around to trying today on my way to work. It's not that I've been lazy, we ripped out all the interior walls and ceiling over the weekend. I got the ceilling back and some of the walls...lots of work left over from the hurricane season still yet to go.
Anyway, I pulled off the line from the EGR vac controller to the EGR valve. Seemed no different with the vac line hanging loose.
Old 03-23-2005, 08:01 AM
Originally Posted by SVXRide
Lee,
-Bill
A+++++++++++
