chenged oil, now reads too full
I had my 92 svx up on the ramps yesterday and changed the oil and filter. Put 6 quarts in, backed off the ramps and filled up to a bit below the full mark. One day later (today) I rechecked the level (to make sure I don't have any leaks etc) and found the engine oil level now reads about 1/4 inch ABOVE the full mark. Silly quesiton, but should I let some out? That just seems like a pain and a real mess. Will the metal gasket that comes along with the OEM filter still work if I loosen the pan drain plug to let some oil out and then re-tighten? How bad is it to have this much more oil in?
Thanks |
Chris, if you put in 6.3 quarts you need not worry. When I do an oil change 6.3 quarts leaves a mark half way between 'L' & 'F'.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited 2012 Outback 3.6R Limited! |
Chris, don't worry about it. It's not too over full to matter if it's just a quarter inch over full.
Re: chenged oil, now reads too full
92 LS-L Claret / Black UR Underdrive Pulley, Bosche Platinum +4 Plugs, K&N Cone Filter http://www.ryanmacdonald.com http://www.digitalvertigo.net http://www.open-innovations.com |
Re: Re: chenged oil, now reads too full
Thanks |
