ignition coils
If I am not mistaken our only option is OEM right? After installing the EUTUNE stage 2av1 today, I still have a rough idle. I pulled all the injector clips one at a time to verify connections, and every time the car stalled. It should run on only 5 cylinders, right? I figure I have possibly multiple bad coils. It runs decentush up top, but it does not idle correctly. I thought it was the cams, but I am almost positive its the coils. They are the only thing that was reused in the build that could causea rough idle. Also, I feel it should pull harder.
That being said, she sounds good and makes good power. I just think she should make more. And she sounds like she has an occasional miss.
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
Re: ignition coils
Do you have a CEL?
Re: ignition coils
It will limp home on 4 cylinders. I had the 2 front coils go on mine at the same time. What about the MAF?
'92 SVX LS Pearl White - 6mt |
Re: ignition coils
Maf is fine. Just got replaced with a z32. No CEL.
Re: ignition coils
i had a bad coil once, didn't give me a check engine light.
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
Re: ignition coils
Good to know, thank you.
Re: ignition coils
same kind of symptoms too. super rough idle. went away at higher rpms. i didn't drive her though, i towed her to the shop, because i had JUST got her back from an oil change from my mechanic (who hates subarus and thinks my dad is a retard for buying me a car this fast for a first car) who i thought drained all the oil so the engine would seize.. turned out i wasn't putting the dipstick in all the way i hate being so paranoid.
