balljoints bad?
how can you tell if theyre bad? mine tends to push a bit in sharp turns, and i get poping/clicking when i turn my steering wheel moving or stationary.
picknpull wants 2 dollars each balljoint, so i want to pull them and want to know how to tell if they're good. also, im looking at the price list, we have mcphereson struts on our cars? i work at a parts store, and i should know this, but im not sure, is this correct? |
Re: balljoints bad?
to test the ball joint on the car raise the tire and grab at the 12 oclock and 6 oclock position and try to pivot up and down. If the tire moves the ball joint is most likely bad. you can test tie rod's by going side to side from the 9 and 3 positions.
Re: balljoints bad?
Yes they are Mcpherson struts.
BTW - installing a used balljoint from a JY is like putting on dirty underwear after you take a shower. Balljoints are usually 25-50 bucks a piece and they are something that shouldn't be reused vehicle to vehicle. Its a safety issue. Balljoints, to be checked correctly need to have the weight of the car/suspension unloaded off the balljoint. If its practical put the car up on a lift and then run a crank jack up under the control arm right next to the ball joint. The shaking the tire at 12 and 6 oclock does work, but a better test is to put a pry bar inbetween the knuckle and the control arm and pry up on the knuckle and watch for up and down movement on the balljoint. Generally play directly up and down will show up before the movement found in shaking the tire at 12/6 oclock. I can draw a pic in MSpaint to explain the physics of the movements I'm talking about if its confusing. |
Re: balljoints bad?
if thats what they cost, ill just buy new ones, for some reason, i was under the impression they were alot mre!
Re: balljoints bad?
new ones are about $70 a side if I remember correctly from doing them in my silver. In any case, you don't want to re-use old ones. Do yourself a favor and get new ones when you can. Also, getting the old ones out will probably destroy the rubber anyway unless you are lucky and for some reason this car doesn't have any undercarriage rust...
Re: balljoints bad?
now, to get mine back together to actually head there. |
Re: balljoints bad?
In case somebody wants to see a bad vs good ball joint:
Re: balljoints bad?
lmao, thats a bit of an extreme case! my right side does have a pinhole leak. When i look at it, it looks fine, but if i move it around, theres a tiny pin sized spot where you see a leak develop after moving it for a few seconds vigorously. when you move it, it is a little to easy to move then im used to playing with new ones all day, but still looser then used ones we get in. i wish i could find a car with one that matches. i could pull all our parts one by one to check at work... but may get in trouble!
