strange abs light
HiGuys
my abslight is bright and shining in my dash but I get no codes under seat Changed both relais and checked the fuses in both boxes Light stays on and there is no abs functioning Any ideas???? Thanks Rinus (netherlands) |
Re: strange abs light
It could be the ABS computer under the seat has failed.
thanks
only solution is buying a new one?? Rinus |
Rinus,
If you send me an email address, I'll forward the Service Manual chapter on the ABS system which may help you track down the problem. When my ABS module failed, it flashed a code 10. Seems like yours isn't getting any power or has suffered a "catastrophic failure" |
Check Ebay, I got one on there.
Not sure if this has been sorted by now or not but we do have a running thread on the svxnation facebook group with several solutions that might help.
. Come Join The Nation We are a combination of both the Network the Forums and a plethora of new bloods! We have close to 6000 members on all forms of social media worldwide. What's all the fuss about? We're just the next logical step in a social media-driven World! As one of the community's longest-running members explained: If the the traditional forums are the library... SVXNATION would most certainly be the popular corner coffee shop www.svxnation.com . |
