Clutch kit for legacy 90 Tranny.
I just woundring about clutch kit for my car.
I use the stock clutch that came whit the Subaru Legacy 2,2L 5speed. And this will not handle the H6 POWER So i was thinking of bye one of these. And the stage 3 is almost the same price but will this fit? Stage 2: http://cgi.ebay.com/F1-RACING-STAGE-...item230c053cae Stage 3: http://cgi.ebay.com/F1-RACING-COMPLE...item230c0369b8 Thanks and this are for cabel clutch.
Alexander (Norway) My subarus: 1992 Svx LSI 5-MT(3.54) 1998 Legacy BG 2.5L GX |
Re: Clutch kit for legacy 90 Tranny.
Looks like either one of those will fit.
the 2.2 cable transmission is compatible with any NA hydro 2.5 clutch. wrx clutches however are out of the question. the only reason the 2.2 and the 2.5s are usually listed separately and with different part numbers is because the OD of the 2.5 clutch disk is physically larger than the oem 2.2 clutch disk. that said, a 2.5 NA clutch will work just fine with the 2.2 cable transmission. just be sure to resurface your flywheel before install. btw, i have a 2.5 clutch and pressure plate paired up with my 2.2 cable tranny and it works perfectly.
94 Acura Integra GSR 97 Legacy Brighton - EG33 Swap still in progress 03 Silverado 2500 - Duramax Last edited by StatGSR; 01-12-2011 at 09:57 AM. |
Ok thanks alot for the answere. Then i go for the stage 3.
