Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
Old 01-07-2007, 03:26 PM
longassname's Avatar
Just some dude.
Significant Technical Input
ECUtune Stage 1v5
Ok, Stage 1v5 is officially done. Dyno plots will have to wait until after I put the new race built transmission in but I can tell you now it's fast. I'm going to make some initial revisions to the website today so those who are waiting for it can order it and I'll make the more extensive revisions in a couple weeks when we have the dyno plots and I'm adding some of the other new products to the website.
For those checking into this thread who haven't been following along in the developments thread, Stage 1v5 is the first part of the new software line up I am working on to be released. I've taken all that we've learned in the development of the prior verssion of stage 2 and stage 3 software and moved it down to the stage 1 software. The stage 1 software is a performance upgrade which does not require the use of any other hardware modifications.
The ECUtune memory adaptor holds two sets of software on it which can be switched between on the fly. The stage 1v 5 software has performance fuel maps which let us run ignition timing maps which greatly improve peformance. The first set of software on the memory adaptor is tuned to get every last drop of performance out of premium unleaded. It runs significanly more ignition advance than the factory software under all acceleration conditions with no correction from the knock sensors being necessary either up or down. The second version of software on the memory adaptor has an ignition timing table tuned to run regular unleaded or nitrous oxide with premium unleaded. Performance with regular unleaded is smooth and quite good but not comparable to the performance with premium unleaded and the stage 1v5 software. The performance of the stage 1v5 software is vastly superior to both the factory software and the prior versions of stage 1 software.
The stage 1v5 software has the rev limiter raised to 7400 rpms and lower rpm tuning to greatly improve performance for cars which have been converted to manual transmissions. With the ECU wired to indicate the transmission is alwasy in the N position there should not be any problems with stalling when the clutch pedal is pressed or when the car is taken out of gear and the pedal is released.
Old 01-07-2007, 04:36 PM
NeedForSpeed NeedForSpeed is offline
I'll be the first to say here,
'Outstanding'!
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 01-07-2007, 05:18 PM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
So, how does the performance of the Stage 1v5 compare with that of Stage 2v5?
____________________________________________
95 LS-i Red, 31,xxx; bone stock for now; Daily Driver
94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light,
2017 Subaru Forester XT, metallic dark gray, 29,xxx
2005 Porsche 911 Turbo S Cabrio, 24,xxx
2006 Subaru Outback LL Bean, 166,xxx sold
92 LSL Dark Teal, Smallcar Shift Kit - sold
Old 01-07-2007, 05:28 PM
Just some dude.
2v6 was the version where we made the jump into the better primary timing map. Performance of 1v5 and 2v6 are comparable--1v5 actually being better at low rpms with a manual transmission. Both would be much faster than 2v5.
Old 01-07-2007, 05:39 PM
Michael,
I think I missed it somewhere? Why was 7400 selected as the fuel cut-off point, and say, not rounded to 7500 rpm? What determined 7400?
Old 01-07-2007, 05:42 PM
Just some dude.
Way back in the day I asked everyone what rpm they wanted for the rev limiter and the consensus came back 7400; it's been 7400 ever since.
Originally Posted by NeedForSpeed
Michael,
Stage 2V6 requires replacement of the injectors, correct?
Old 01-07-2007, 05:43 PM
Just some dude.
No 2v6 does not require replacement of the injectors. That's the soon to come 2v7 software.
Old 01-08-2007, 10:23 AM
Just to be clear, as you have mentioned a couple solutions for the stalling with factory programming in MT converted cars, will the new software still drop fuel and timing to zero when decelerating with the auto, just as stock programming does? Does this programming benefit fuel economy?
Then, the MT guys will wire the ECU to N, to be covered in another thread? If the MT guys can get around this, and the autobox guys can get all the economy available off throttle, that's perfect.
Old 01-08-2007, 10:29 AM
Just some dude.
That is correct. The stage 1 software still has the fuel cut on decell just like factory.
Then the mt guys will wire the ECU to N to deactivate the fuel cut on their cars. If that doesn't work I will make them a 2nd version specifically for manual transmissions. I am not removing the fuel cut from the standard software for automatic SVXii.
Old 01-08-2007, 12:36 PM
mikecg's Avatar
mikecg mikecg is offline
Send a message via AIM to mikecg Send a message via Yahoo to mikecg
Quick question, wont wiring the ECU to see nutral all the time disable the cruise control? I thought that was why we set the car up to see nutral when the clutch was pushed in. That way the cruise control could be used and it would shut off if you pressed the clutch in. I've also learned to not push the cltch in until the engine is below 2000rpms when stopping. That seems to prevent the stall, because the engine is under load still while stopping.
Old 01-08-2007, 12:44 PM
Just some dude.
I'm not sure but you may well be right. I wasn't thinking of that. I'll have the test bunny pay attention to that too. If that is the case then I will make a seperate version for cars with manual transmissions. When I am in front of the factory service manual I will pay attention to if the signal to the cruise control computer is actually coming from the ecu or if it was originally just on the same circuit. If they are just on the same circuit we can wire them seperately so that the ecu always thinks it's in N but the cruise control only thinks it's in N when the clutch is pushed in. Even if the cruise control computer is getting its signal from the ecu if its just a high/low switch we can wire it seperately.
Old 01-08-2007, 12:55 PM
Well...wouldn't wiring the clutch peddle up to show neutral when you press in the clutch peddle FIX the stall problem?
As the ECU would see it as being in neutral (when coasting with the clutch de-pressed) so it wouldn't cut the fuel?
That is how I wired mine, and I never had a stall problem...so maybe that's why....I only wired it that way to make the cruise control work....
Just some thoughts...
