Sring rate on front struts?
Would someone with the FSM's look up the stock spring rates in pounds per inch for the front struts for me.
TIA
140 lbs/in. The rears are 110 lbs/in.
Thanks
I guess its all about making sacrifices. Doug
That stock spring rate is kinda weak...
-Chike Quote:
and just look, the 30 lbs/in difference gives you a built-in understeer condition. Mychailo - what's the relationship between sway bar rate and coil spring rate (i.e. how much will increasing the sway bar rate contributes to the overall spring rate at the wheel) -- is it just a linear relationship?
-Bill
Mychailo :: 2006 Silver Mitsubishi Evolution 9, E85, 34 psi peak, 425wtq/505whp DJ :: 1995 Laguna Blue SVX L AWD 5MT (sold) Visit my locker SVX Mods: ND iridium spark plugs, Impreza RS fpr, afr tuned to 13.2:1 using a custom MAF bypass, custom exhaust, WRX 5MT w/ STi RA 1st-4th gear & stock WRX 5th gear, Exedy 13 lb flywheel & Sport Clutch, STi Group N tranny & engine mounts, urethane spacers in rear subframe, rear diff mounts, and pitch stopper, SVX Sport Strut Springs (185f/150r), custom 19 mm rear swaybar, urethane swaybar mounts, Rota Torque 17x8", 225/45-17 Proxes 4 tires, Axxis Deluxe Plus organic brake pads. Last edited by mbtoloczko; 06-16-2004 at 10:31 AM. |
So the 19mm rear bar basically balances out the front and rear spring rates....interesting.... -Bill
OT? OT? who, me?
Agree on the add/subtract aspect of the bar when leaning in a turn. I now return you to your regularly scheduled thread... -Bill
