Thread Tools | Rate Thread | Display Modes |
#151
LAN do you need more 2v6 test people? If so and if you need to know how it feels with a mostly stock car in sub zero weather I can pick one up from you this week.
If not, hey I was gonna spring for it within the next couple months anyways.
#152
There is one interesting phenomenon I have noticed. When I lift of the throttle maybe in 2nd or 3rd gear and the rpm's drop down to maybe 2000 or so, there is a sudden onset of engine braking I can massage the accelerator very slightly and make it come on and go off. As rev's drop, foot off the accelerator, a a point, it feels like I suddenly hit the brakes. Touch the accelerator pedal very slightly, seems like brakes come off, car is still slowing down, rev's dropping, but not nearly so quickly. It's a real on-off thing. Could this be an artifact of my automatic throttle bypass valve being disconnected? Guess I will know nextweek, when I reconnect it.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold Last edited by shotgunslade; 11-14-2006 at 08:40 PM. |
#153
Oh thanks, I appreciate the sentiment but no I was just looking for feedback when the suggestion that I invest in dyno time was put forward. Development is done. Purchase whenever you are ready.
Thanks Quote:
#154
#155
the upgrade price from v5 to v6 isn't that bad. need the link to our website?
Sorry if my comments upset you. I was inferring from your earlier comment that there have been many more Vanagons with 2v6 chips than SVXs with 2v6 chips, thus significant net income in your bank account (based on the premise that your profit on 2v6 kits runs somewhere in the neighborhood of $125 to $600/kit, depending on the option purchased - valid only if one takes it as a given that your up front investment has already been covered) that you could invest in further documented improvements in your EG33-based line. By documented, I'll refer to your web site: As the figure notes, this is a 2v4-based dyno run (not a 2v5 or 2v6), utilizing a dyno running directly off of the wheel hubs (thus eliminating the parasitic loses resulting from a roller-based dyno (DynoJet) -which the majority of SVX dyno runs have utilized - and producing nominally higher calculated crank Hp/Tq figures if one doesn't correct for the loses). What is striking is that there are no AFR curves to go with the Hp and Tq curves. As someone with your tuning skills knows, the relationship between AFR and Hp/Tq is a significant one. What would be truly exciting would be to see a series of dyno plots that demonstrated the relationship between the AFR you had "tuned" in and the resultant Hp/Tq produced (a potentially strong selling point when it comes to upgrading from your Stage 1 to Stage 2 products). "...interative improvements resulting from months of my own road testing and the feedback provided by end users." Again, as the skilled tuner you are, you recognized the significant difference between a "street tune" and a "dyno tune" (i.e. "butt dyno" versus "quantified data"). For documented improvements, dyno runs are the gold standard and are the only way the EG33 will ever be able to fully realize its full performance potential. Turning you lose on a DynoJet for 2-3 hours with a series of incrementally different chips and posting the results would be exciting. Thank you so much for everything you've done for the SVX performance community and I look forward to great things in the future.
Maximum acceleration, maximum lateral g-force...it can be done, it just takes time and $$$ |
#157
I wasn't upset. I was confused at how you could possibly take a low volume of svx sales to equate to my having loads of money and I was trying to give you a reality check which obviously didn't sink in.
Your new post though is a little insulting and missguided. You can't equate a roller dyno to giving lower results due to parasitic losses. They give whatever results they are calibrated to give and as a general rule dynapacs give lower #'s than dynojets. While saying what an experienced tuner I am you've insinuated that the "nominally higher" results "if not corrected for the losses" (your so called parasitic dynojet roller losses) aren't impressive. Those aren't calculated #'s either by the way. They are wheel readings taken with the same car on the same dyno in the same session within minutes of each other with only the software/maf meter change in between. That's how you show real gains. That plot was just taken from during my development of the z32 maf meter software. As for why there is no afr posted in the plot, as stated in the thread where we discussed the development of the z32 maf meter software the pipe the dyno operator has the wideband installed to wouldn't fit in the tailpipe of the test car. None the less I knew exactly what the afr was as I always do since my car has a wideband and that plot wasn't intended to prove anything to you--it was part of my tuning. Speeking of my tuning......ie butt dyno vs real dyno...your typical wide open throttle dyno plot only captures a very small portion of the operating conditions I tune for. A dyno is a great tool but no it is not the gold standard one and only way to tune. If you leave the street tuning out then you leave out 95% of the tuning. Say it's 75 degrees the day of the dyno tuning what about when it's 100 degrees or 44 degrees? You have to spend months on the street to get that tuned. There are all kinds of things you never see on the dyno. A few hours on the dyno is great but it's no substitute for "months of itterative improvements" made on the street. So ya I'm sitting here wondering why you would throw in all those slights about the quality of the information I've shared and the way I tune not being the way you think I should along with thanking me for what I've done and saying you look forward to what I will do--what when I start tuning on a dynojet dyno for 3 hours? Would you like to explain to me the rest of how to retune an svx ecu? I'd love to have more dyno plots but slighting the last one and the methods used to tune since it aren't going to get you new plots any sooner. Quote:
#158
Tom |
#159
No it wasn't.
Jesus could anyone be any less appreciative.
2v6 is an incredible product and my SVX is twice the car it was without it. I have plenty of timing up where i need it in all the load levels(not just a wot) I don't understand why you all choose to bite the hand that feeds, you will end up sucking your own thumb. phil
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
#161
-Bill (holding out for v8 )
#162
Mike changed his mind because he decided to go another direction with his internal R&D. Life happens I've got some other mechanical upgrades I'm working on that I'll be talking with Mike about to make sure they work perfectly with his software -Bill
Retired NASA Rocket Scientist Most famous NASA "Child" - OSIRIS-REx delivered samples from asteroid BENNU to Earth in Sept. 2023 Center Network Member #989 '92 Fully caged, 5 speed, waiting for its fully built EG33 '92 "Test Mule", 4:44 Auto, JDM 4:44 Rear Diff with Mech LSD, Tuned headers, Full one-off suspension '92(?) Laguna, 6 spd and other stuff (still at OT's place) My Locker Last edited by SVXRide; 11-16-2006 at 09:10 AM. |
#163
Mr. LAN,
Sorry if my translating didn't come out write on paper, I did not mean to insult or insinuate. Let me try to clear things up below.... Quote:
#164
fair enough
#165
I'm still anxious to hear from people running 2v6 with manual transmissions.
I'd also like to hear how many people would like to run 370cc injectors. |
