Whats the black plastic box bolted under intake?
I started replacing all the vaccum lines today and broke one of the ports off the black plastic box bolted to the bottom side of the intake. What is this thing? does anyone have a part number?
Thanks in advance, Steve
1992 SVX lsl - >111K, pearl, 4.44 gears, ECUtune stage 1 2005 Outback XT wagon - i love that turbo!!!! 2004 Dodge Ram 1500 Hemi |
Is this 'black box' in the fender? If so, then you're talking about the intake resonator. If not, are you talking about something attached to the air filter intake pipe? Are you even referring to the MAF (that's a black box) which sits between the air filter box and intake tube? -Chike ?????
I think you are referring to the air control valve, located under the throttle body. See part #2 HERE
What I'm looking at is attached to the under side of the intake manifold. I removed the manifold to replace the brittle vaccum and pvc air lines. There are several solenoids under the intake, but this part has only two vaccum lines attached to it and is located near the middle of the front of the manifold on the bottom side. I think its about 3" wide by 2" deep by 3-1/2" long constructed of black plastic. I'll try to post some pictures tonight
Steve
I looked at the part again. I think its just a vaccum resevoir. Any thoughts, part numbers???
Mike.... 8/96......Vin 100109 1997 LSI,18 inch Axis wheel(summer),16 inch ALT wheels(winter),Trans temp/Volt gauges,Iridium plug's, Autotechnica intake,silverstar high/low and fogs,polyurethane sway bar bushing's front and rear,Smallcar shift kit,Stebro exhaust finally..SWEET!! Motorsports drilled/slotted rotor's front and rear with ceramic pads and SS brake lines. 1997 SUS Legacy,finally got the engine in after a year!! My Locker www.myspace.com/devilhornz |
