Old 05-18-2008, 03:05 PM
kwren's Avatar
kwren kwren is offline
Gasoline octane?
I suppose the general consensus is that the higher octane gasoline is better to burn in our SVX's. What does the higher octane do that is different than the regular?
What could result in maybe mixing half a tank of each instead of a full tank of one or the other?
Anyone know?
Thanks,
Keith
Old 05-18-2008, 03:16 PM
lilbrudder lilbrudder is offline
i can make it on my oooowwwnn!
higher octane = less ping and knocking = ME
i always use 91 fuel but just recently started adding octane boosters, my engine has been noticeably smoother and quieter.
Old 05-19-2008, 11:00 AM
dcarrb dcarrb is offline
This would concern me. My cars start enthusiastically, idle contentedly and run strong, and I run a mix of grades from the cheapest joint in town.
Fuel additives, injector cleaners, octane boosters and other high-priced magic potions are marketed specifically to separate money from your wallet. Most may "work" in some respect, a few may not, but the thing is, you don't need a one of 'em.
Does anybody still make a lead substitute for old engines designed to burn leaded gas? That would be an exception to the additive rule.
dcb
Old 05-19-2008, 02:25 PM
Ownbot's Avatar
Ownbot Ownbot is offline
I'm the anti-do-gooder
I have been told that the higher octane gas just has more impurities so It will ignite at a higher temp, thus being more "dirty" and not as good for your engine as a lower octane "cleaner" fuel.
Old 05-19-2008, 02:45 PM
Subix's Avatar
Subix Subix is offline
My Other car is a GENIUS Car!
The only impure thing about premium gas is the price tag associated with it.
1994 subaru svx le 112k
Old 05-18-2008, 03:21 PM
Old 05-18-2008, 03:23 PM
^oops, sorry. my web sux here!
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Premium is not "better" than regular. It has a higher octane and it burns less easily.
On higher compression engines like ours, the higher detonation temperature of premium helps to prevent pre-ignition.
Old 05-19-2008, 01:02 AM
kwren's Avatar
does burns [I]less [/I]easily...
mean the higher octane actually burns slower?
Thanks,
Keith
Old 05-19-2008, 05:28 AM
Yes. 1234567890
'92 SVX LS Pearl White - 6mt
Old 05-19-2008, 08:39 AM
lechnoid's Avatar
lechnoid lechnoid is offline
Tech & Almost Lawyer
Fuel's octane rating measure it's ability to reduce knock. The higher the octane fuel, the slower and more controlled the burn is. Running fuel with too high of a rating (without proper tuning) will have you running rich and leave more unburnt fuel going into the exhaust. This can lead to premature catalytic converter failure.
This discussion does bring up an interesting point though. What is the recommended octane rating for the SVX? I know it says mid-grade, but what octane that is depends on what part of the country you're in. I lived in Nevada for 3 years. Out there, premium was 91 octane. In Minnesota, premium is 93 and sometimes 94, with the 94 usually being 10% ethanol.
Additive octane boosters are generally bad. Generally being about 98% of the time. If you're paying less than $40-50 for a bottle of it, likelihood is that it is wearing away at your fuel pump and injectors because of what is used to make it. Same goes for over the counter injector cleaners.
Instead just avoid going to the cheapest gas station in town and go to one of the more expensive, bigger named places. In general, their fuel will be cleaner, have better additives (from the refinery, not the parts store), be more stable, and have more accurate octane ratings. Also, go to the busier gas stations, as they get fresh refills more regularly. Gas loses octane as it sits, but that's usually over longer times, but also the holding tanks collect moisture inside through condensation over the course of a day's warming/cooling cycle. The more days the gas sits, the more water you'll end up with in it.
I think I'll get off my fuel soap box now and go have a bowl of Lucky Charms.
Old 05-19-2008, 04:52 PM
oab_au oab_au is offline
Can't agree with this bit!
There is no different in the burn speed of 92 octane to 98 octane. The only difference is in the 'flash point' of the fuel. This is the temp/pressure that the fuel can stand before it will self-ignite. A higher octane can stand a higher combustion chamber temp/pressure, before it will self-ignite/detonate.
It won't make it run rich or hurt the cats.
One Arm Bloke.
Tell it like it is!
