SVXBot
Old 08-12-2019, 03:01 PM
nationofzeros nationofzeros is offline
SVX Climate Control Digital Temperature Fault
Hi all
My UK RHD SVX has developed the classic problem with the climate control unit, where it keeps counting down & resetting to the default temperature (18 deg C in this case), 'saving' & then batch processing requests for outside T, and generally making lots of irritating beeps while in this mood
I am sure I saw a fantastically detailed write up with pictures, of how to extract the control unit from the dash, and fix the problem (capacitor leaking onto a PCB) but I can't find it !
Please could a kind person send me the link ?
Many thanks
Old 08-12-2019, 04:52 PM
oab_au oab_au is offline
Re: SVX Climate Control Digital Temperature Fault
Here you go.
http://www.subaru-svx.net/forum/showthread.php?t=62752
One Arm Bloke.
Tell it like it is!
Old 08-13-2019, 01:20 PM
That's great - thanks !
Old 08-13-2019, 01:25 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
good to see that people still find it useful - I have now fixed about 30 units...only one has come back with a different fault.
Old 10-15-2019, 02:47 PM
Hi ; it really is fantasically useful ! I really appreciate this service to the RHD community.
I stripped down my air con unit only to find someone had been there before me & fitted a larger capacitor ! I put a new one in for good measure, using my pathetic amateur soldering skills, but there was quite a bit of board damage from previous leaks, and on refitting I was getting the fault again, intermittently
I bit the bullet and bought a second unit S/H from Japan - I took it apart this evening and the board / (original) capacitor both look absolutely fine. I will put it in this weekend - hoping for the best !
All the best & thanks again
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
2001-2015 SVX World Network
