Spark Advance
What is normal for idle and at around 2500RPM cruising on the highway, level ground?
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
Re: Spark Advance
Well if you are talking about a SVX, its about,10* to 20* BTDC at idle, it changes around to control the idle speed.
Light throttle cruise about 55* to 65* BTDC, when the pedal is on the floor would go to about 34* BTDC.
Re: Spark Advance
So, correct me if I am wrong but 50 degrees while cruising would indicate that there is NOT a knocking problem, correct? The number goes up if knocks are sensed, right?
