Old 11-27-2015, 03:51 PM
slowner44's Avatar
slowner44 slowner44 is offline
97 Bordeaux Pearl Part-out
Hey, I've had this parts car for a while, took what I needed, and now have lots of parts for sale either through eBay or message me on the forums. I've sold a bit off already so just ask if there's any part you need and Ill tell you if I can help you out.
Its a 97 LSi, with the Bordeaux peal/claret paint and beige interior
Old 11-28-2015, 11:57 AM
bishop bishop is offline
Re: 97 Bordeaux Pearl Part-out
Manual seat belts and associated parts?
Old 11-28-2015, 01:45 PM
slowner44's Avatar
I still have all the seat belts, are you interested in just the front two or all four?
Old 11-28-2015, 05:49 PM
Just the front two to do a manual seat belt conversion on my 92.
Old 11-29-2015, 02:36 PM
shotgunslade's Avatar
Security fob?
Old 11-29-2015, 02:39 PM
slowner44's Avatar
Originally Posted by shotgunslade View Post
Security fob?
Sorry, I can't help you there
Old 11-30-2015, 03:16 PM
Jvan Jvan is offline
I need both driver/passenger doors since both of mine have started to rust by the lower door panels. I know shipping will be a problem ( I have had doors shipped by Greyhound for a restoration project but they didn't have glass). I also need the rear AWD transmission support mount ; my transmission just failed after a rebuild because the support/mount failed and allowed the transmission to wiggle allowing all the trans fluid to leak out. The rear support should be easy to send, unlike the doors.
Old 12-01-2015, 08:04 PM
slowner44's Avatar
I know one of the doors has a large chip which reveals a sizable portion of bare metal that is starting to get rust on it. Id have to check the other one, and could send pictures.
Old 12-02-2015, 08:06 AM
Sending photos would be great. What about the rear trans mount? Is the rubber still in good condition? The rubber insert deteriorated and didn't hold the rear of the transmission. thus the leaking trans fluid.
Old 03-15-2016, 05:22 PM
slowner44's Avatar
Bump!
Made a date with the scrap yard so if anyone is still looking for parts make sure to let me know before April 1st, I'll see if I can help you out.
Old 03-18-2016, 04:24 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
What about lights, what ones are left?.
Old 03-18-2016, 09:38 PM
slowner44's Avatar
Both headlights (not including corner pieces)
the left tail light
both tail light extender/side marker
Old 03-21-2016, 12:40 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
You have a PM
1995 POLO LSI 76K MILES SOLD
Old 03-21-2016, 09:17 PM
SVX92-97's Avatar
Thanks for the parts Riley
Old 03-21-2016, 09:21 PM
DallasSVX92's Avatar
DallasSVX92 DallasSVX92 is offline
Some pics would be nice! I'm always looking for miscellaneous parts. Im in need of a driver side front quarter panel
