Comtemplating dash removal project.
I am getting a little tired of not being able to easily change which vent the heat or AC comes out of. It's been this way for a few years and I have been reluctant to fix it because the dash has to be removed or at least pulled back a bit to get at the left side mix motor. I know it is going to be a huge pain to do it, but what I was wondering was how likely is it that something gets screwed up in the process? I am hoping that it is just a matter of a lot of nuts and bolts, time and patience rather than something with a great likely hood of causing electric problems. Any thoughts or advice from those that have done this?
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
Re: Comtemplating dash removal project.
It's actually only about a dozen or so screws/bolts since yours is a 92 and not overly terrible.
The procedure is in the manuals which I know have been posted all over lately. |
If the problem is just the air mix motor (#2 in diagram), you can change it from under the dash, passengers side, by the center console. It helps to have a son who can contort his body to see the two bolts that hold it in. The two control rods for heat to cooling just clip into it.
Gene [IMG][/IMG]
Gene and Ben 1992 SVX LS AWD 110K - Liquid Silver 1994 SVX LSi AWD 128K - White Pearl (daily driver) 1994 SVX LSi AWD 95K - Emerald Pearl (sold) 1992 SVX LS-L AWD 115K - Dark Teal 4.44 swap (sold) |
The problem is the motor on the drivers side. #1 in that diagram. It is almost, but not quite accessible. You can't get a screw driver on the rear most screws (or is it bolts? I can't quite remember).
So I can say for sure that changing this motor is possible without removing the dash.
Using one of those mini thumb wheel screw drivers I was able to unscrew the three screws holding it, but the real trick is that the metal rod has to be removed before the motor will slide out. There is hinged clip that has to be pushed off the rod using a long thin screw driver, then pull the rod towards the motor till it slides free. Once the screws and rod are removed it will come out. I'm very happy about this, it been about 4 years since my motor went bad and I thought more sure I would have to remove the dash to replace it. Having a used Heater core to reference was big help. Once I finally figured out what to do it only took about an hour to replace it.
I've replaced it from below - didn't think it was too difficult
/T |
well considering that I tried to remove it unsuccessfully on 2 other occasions and posted asking advice several times, I came to the conclusion that it was not possible without pulling the dash away. Once you know how to do it it seems simple.
Yeah, sorry - I didn't realize you did it already. I didn't read you last posting carefully. Didn't mean to be rude.
/T |
Congratulations Sean! A victory of any kind is a victory nonetheless.
1995 Caterham 7 Twincam 2002 Porsche 911 targa -- now with FSI 4.0L power! 2007 BMW 328i Cabriolet 2012 Tacoma 4wd v6 Access Cab 2013 Mercedes E350 4Matic Wagon 2005 STi - totaled after 10 great years 1994 SVX LSi 5spd - sold but not forgotten 2000 Legacy GT 5spd sedan - gone after 150K miles of bliss |
