found red thick cable beside battery cable
Hi:
q for a svx 94 I was replacing the battery, and when I conected the positive terminal with the positive cables(there's two cables), i found i thick red cable disconected that goes inside like a black box. Where does this cable go? Also i had to change the baterry because all the acid came out... I use this car once every two months, the battery is like 3 years old, is this normal... or is it because of lack of use...i mean what provoked this? |
The acid came out of the battery? Is it all over the car, or did it evaporate? I haven't seen a battery go dry before. The battery in my SVX is 4+ years old, OEM Subaru, and the battery in my Taurus was over 7 years old when I replaced it. Never had an issue with fluid levels.
What kind of battery is it? (manufacturer?) I can't help you with the wiring, but someone will jump on shortly.
There should be a cable off of the positive terminal that goes into the fuse box under the hood.
-Bill
red cable?
the cable goes into a box that says stinger, then there is a red button and then black lever that says reset. the cable is disconeected but seemd like the car works normally
battery acid, i'm located in miami probably was the heat??? |
Yeah that's a stinger brand breaker. They are easier to deal w/ than blown fuses in what would normally be a fuse block there.
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." Benjamin Franklin blk 92' LSL w/ average mods pics here http://s306.photobucket.com/albums/nn277/yourconfused/ Cash68: "Hmm, I wouldn't brag about beating Escorts. That's like saying you tricked a retarded person." |
Thread Tools | |
Display Modes | |
